AutoCad 2004 Operating System
Welshman
Computer
GB
Will AutoCad 2004 run on windows 98 or are there known problems?
Or is it simply that Acad 2004 does not run on Win 98
Welshman
The file format types is different on windows\98 system. Current windows\200 and obove use file format is NSFT. I do not believe that there is a backward conversion to windows\98 file format. You might try the current conversion program to see if you can do this. Hope this helps - John
