Attribute of Type Number
PDW
Automotive
BE
Dear all,
I have, based on thread Link, adapted the Journal and added some more Attributes to fill-in or automatic filled in.
Only with the TextBox11.Text = workPart.GetStringAttribute(myAttributeTitle(10)) i have an issue.
In my NX file the Attribute is not a String Attribute, but of the Type Number.
Does anybody knows a solution for this?
Using NX11, no Database
Code:
'Release "QUA_Set_PartFileAttributes.vb"
'Drive:\Customer\XXXX\Mould\Final\XXXX-YYY.prt
'Drive:\Customer\XXXX\Tool\XXXX-YYY-ZZZ.prt
'This journal updates, based on the OS File Name, several extracted Attributes
'FILE_PATH
'FILE_NAME
'Part_Spec
'PART_NAME
'MOULD_NR
'CUSTOMER_NAME
Option Strict Off
Imports System
Imports NXOpen
Imports System.Windows.Forms
Module Module1
    Dim theSession As Session = Session.GetSession()
    Public workPart As Part = theSession.Parts.Work
    Sub Main()
	    workPart.SetAttribute("FILE_PATH", GetFilePath())
	    workPart.SetAttribute("FILE_NAME", GetFileName())
	    workPart.SetAttribute("Part_Spec", (GetFilePath() & GetFileName())&".prt")
	    workPart.SetAttribute("PART_NAME", GetFilePartName())
	    'workPart.SetAttribute("MOULD_NR", GetFileMould())
	    workPart.SetAttribute("CUSTOMER_NAME", GetFileCustomerName())
        Dim myDialog As New Dialog1
        myDialog.myPart = workPart.FullPath
        myDialog.ShowDialog()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
	Function GetFileName()
	Dim strPath as String
	Dim strPart0 as String
	Dim pos0 as Integer
	'get the full file path
	strPath = workPart.fullpath
	'get the part file name
	pos0 = InStrRev(strPath, "\")
	strPart0 = Mid(strPath, pos0 + 1)
	strPath = Left(strPath, pos0)
	'strip off the ".prt" extension
	strPart0 = Left(strPart0, Len(strPart0) - 4)
	GetFileName = strPart0
End Function
Function GetFilePath()
	Dim pos0 as Integer
	GetFilePath = strPath
End Function
Function GetFilePartName()
	Dim pos0 as Integer
	strPath = Right(strPath, pos0)
    'strip off the "XXXX "
	strPart0 = Right(strPart0, Len(strPart0) - 5)
	GetFilePartName = strPart0
End Function
Function GetFileCustomerName()
	Dim strPart1 as String
	Dim strPart2 as String
	'Dim strPart3 as String
	'Dim strPart4 as String
	Dim pos0 as Integer
	Dim pos1 as Integer
    Dim pos2 as Integer
    'Dim pos3 as Integer
    'Dim pos4 as Integer
	strPart0 = Left(strPath, pos0 - 1)
    pos1 = InStrRev(strPart0, "\")
	strPart1 = Right(strPart0, Len(strPart0) - 3)
    pos2 = InStr(strPart1, "\")
	strPart2 = Left(strPart1, pos2 - 1)
    'pos3 = InStrRev(strPart2, "\")
	'strPart3 = Left(strPart2, pos3 - 1)
    'pos4 = InStrRev(strPart3, "\")
	'strPart4 = Left(strPart3, Len(strPart3) - 5)
	GetFileCustomerName = strPart2
End Function
'Function GetFileMould()
	'Dim strPath as String
	'Dim strPart0 as String
	'Dim strPart1 as String
	'Dim strPart2 as String
	'Dim pos0 as Integer
	'Dim pos1 as Integer
    'Dim pos2 as Integer
	'strPath = workPart.fullpath
	'pos0 = InStrRev(strPath, "\")
	'strPart0 = Left(strPath, pos0 - 1)
    'pos1 = InStrRev(strPart0, "\")
	'strPart1 = Right(strPart0, Len(strPart0) - 3)
    'pos2 = InStr(strPart1, "\")
	'strPart2 = Mid(strPart1, pos2 + 1)
    'pos3 = InStr(strPart2, "\")
	'GetFileMould = strPart3
'End Function
End Module
Public Class Dialog1
    Public myPart As String
    Private myAttributeTitle(23) As String
    Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
        Me.DialogResult = System.Windows.Forms.DialogResult.OK
        Try
            workPart.SetAttribute(myAttributeTitle(0), TextBox1.Text)
        Catch ex As Exception
            MsgBox(myAttributeTitle(0) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(1), TextBox2.Text)
            MsgBox(myAttributeTitle(1) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(2), TextBox3.Text)
            MsgBox(myAttributeTitle(2) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(3), TextBox4.Text)
            MsgBox(myAttributeTitle(3) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(4), TextBox5.Text)
            MsgBox(myAttributeTitle(4) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(5), TextBox6.Text)
            MsgBox(myAttributeTitle(5) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(6), TextBox7.Text)
            MsgBox(myAttributeTitle(6) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(7), TextBox8.Text)
            MsgBox(myAttributeTitle(7) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(8), TextBox9.Text)
            MsgBox(myAttributeTitle(9) & " : " & ex.Message)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(9), TextBox10.Text)
        End Try
        Try
            workPart.SetAttribute(myAttributeTitle(10), TextBox11.Text)
            MsgBox(myAttributeTitle(10) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(11), TextBox12.Text)
            MsgBox(myAttributeTitle(11) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(12), TextBox13.Text)
            MsgBox(myAttributeTitle(12) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(13), TextBox14.Text)
            MsgBox(myAttributeTitle(13) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(14), TextBox15.Text)
            MsgBox(myAttributeTitle(14) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(15), TextBox16.Text)
            MsgBox(myAttributeTitle(15) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(16), TextBox17.Text)
            MsgBox(myAttributeTitle(16) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(17), TextBox18.Text)
            MsgBox(myAttributeTitle(17) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(18), TextBox19.Text)
            MsgBox(myAttributeTitle(18) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(19), TextBox20.Text)
            MsgBox(myAttributeTitle(19) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(20), TextBox21.Text)
            MsgBox(myAttributeTitle(20) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(21), TextBox22.Text)
            MsgBox(myAttributeTitle(21) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(22), TextBox23.Text)
            MsgBox(myAttributeTitle(22) & " : " & ex.Message)
        End Try
		Try
            workPart.SetAttribute(myAttributeTitle(23), TextBox24.Text)
            MsgBox(myAttributeTitle(23) & " : " & ex.Message)
        End Try
		Me.Close()
    End Sub
    Private Sub Cancel_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel_Button.Click
        Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.Close()
    End Sub
    Private Sub Dialog1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Me.Text = myPart
        myAttributeTitle(0) = "CUSTOMER_NAME"
		myAttributeTitle(1) = "PROJECT_NAME"
        myAttributeTitle(2) = "CUSTOMER_PART_NR"
		myAttributeTitle(3) = "ITEM_NR_CMS"
		myAttributeTitle(4) = "MOULD_NR"
        myAttributeTitle(5) = "DESCRIPTION.1"
		myAttributeTitle(6) = "DESCRIPTION.2"
        myAttributeTitle(7) = "MATERIAL.1"
		myAttributeTitle(8) = "MATERIAL.2"
        myAttributeTitle(9) = "SHRINKAGE"
		myAttributeTitle(10) = "SHOT_SIZE"
		myAttributeTitle(11) = "TREATMENT"
		myAttributeTitle(12) = "QUANTITY"
        myAttributeTitle(13) = "PART_NAME"
        myAttributeTitle(14) = "TOL_GROUP"
		myAttributeTitle(15) = "DRAWN"
        myAttributeTitle(16) = "DATE_DRAWN"
		myAttributeTitle(17) = "CHECKED"
		myAttributeTitle(18) = "DATE_CHECKED"
		myAttributeTitle(19) = "APPROVED"
		myAttributeTitle(20) = "DATE_APPROVED"
		myAttributeTitle(21) = "RELEASE_STATUS"
		myAttributeTitle(22) = "FILE_NAME"
		myAttributeTitle(23) = "FILE_PATH"
        Try
            TextBox1.Text = workPart.GetStringAttribute(myAttributeTitle(0))
        Catch ex As ApplicationException
            'attribute does not exist
            TextBox1.Text = ""
        End Try
        Label1.Text = myAttributeTitle(0)
        Try
            TextBox2.Text = workPart.GetStringAttribute(myAttributeTitle(1))
            TextBox2.Text = ""
        End Try
        Label2.Text = myAttributeTitle(1)
        Try
            TextBox3.Text = workPart.GetStringAttribute(myAttributeTitle(2))
            TextBox3.Text = ""
        End Try
        Label3.Text = myAttributeTitle(2)
        Try
            TextBox4.Text = workPart.GetStringAttribute(myAttributeTitle(3))
            TextBox4.Text = ""
        End Try
        Label4.Text = myAttributeTitle(3)
        Try
            TextBox5.Text = workPart.GetStringAttribute(myAttributeTitle(4))
            TextBox5.Text = ""
        End Try
        Label5.Text = myAttributeTitle(4)
        Try
            TextBox6.Text = workPart.GetStringAttribute(myAttributeTitle(5))
            TextBox6.Text = ""
        End Try
        Label6.Text = myAttributeTitle(5)
        Try
            TextBox7.Text = workPart.GetStringAttribute(myAttributeTitle(6))
            TextBox7.Text = ""
        End Try
        Label7.Text = myAttributeTitle(6)
        Try
            TextBox8.Text = workPart.GetStringAttribute(myAttributeTitle(7))
            TextBox8.Text = ""
        End Try
        Label8.Text = myAttributeTitle(7)
        Try
            TextBox9.Text = workPart.GetStringAttribute(myAttributeTitle(8))
            TextBox9.Text = ""
        End Try
        Label9.Text = myAttributeTitle(8)
        Try
            TextBox10.Text = workPart.GetStringAttribute(myAttributeTitle(9))
            TextBox10.Text = ""
        End Try
        Label10.Text = myAttributeTitle(9)
        Try
            TextBox11.Text = ""
        End Try
        Label11.Text = myAttributeTitle(10)
		Try
            TextBox12.Text = workPart.GetStringAttribute(myAttributeTitle(11))
            TextBox12.Text = ""
        End Try
        Label12.Text = myAttributeTitle(11)
		Try
            TextBox13.Text = workPart.GetStringAttribute(myAttributeTitle(12))
            TextBox13.Text = ""
        End Try
        Label13.Text = myAttributeTitle(12)
		Try
            TextBox14.Text = workPart.GetStringAttribute(myAttributeTitle(13))
            TextBox14.Text = ""
        End Try
        Label14.Text = myAttributeTitle(13)
		Try
            TextBox15.Text = workPart.GetStringAttribute(myAttributeTitle(14))
            TextBox15.Text = ""
        End Try
        Label15.Text = myAttributeTitle(14)
		Try
            TextBox16.Text = workPart.GetStringAttribute(myAttributeTitle(15))
            TextBox16.Text = ""
        End Try
        Label16.Text = myAttributeTitle(15)
		Try
            TextBox17.Text = workPart.GetStringAttribute(myAttributeTitle(16))
            TextBox17.Text = ""
        End Try
        Label17.Text = myAttributeTitle(16)
		Try
            TextBox18.Text = workPart.GetStringAttribute(myAttributeTitle(17))
            TextBox18.Text = ""
        End Try
        Label18.Text = myAttributeTitle(17)
		Try
            TextBox19.Text = workPart.GetStringAttribute(myAttributeTitle(18))
            TextBox19.Text = ""
        End Try
        Label19.Text = myAttributeTitle(18)
		Try
            TextBox20.Text = workPart.GetStringAttribute(myAttributeTitle(19))
            TextBox20.Text = ""
        End Try
        Label20.Text = myAttributeTitle(19)
		Try
            TextBox21.Text = workPart.GetStringAttribute(myAttributeTitle(20))
            TextBox21.Text = ""
        End Try
        Label21.Text = myAttributeTitle(20)
		Try
            TextBox22.Text = workPart.GetStringAttribute(myAttributeTitle(21))
            TextBox22.Text = ""
        End Try
        Label22.Text = myAttributeTitle(21)
		Try
            TextBox23.Text = workPart.GetStringAttribute(myAttributeTitle(22))
            TextBox23.Text = ""
        End Try
        Label23.Text = myAttributeTitle(22)
		Try
            TextBox24.Text = workPart.GetStringAttribute(myAttributeTitle(23))
            TextBox24.Text = ""
        End Try
        Label24.Text = myAttributeTitle(23)
    End Sub
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Dialog1
    Inherits System.Windows.Forms.Form
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()> _
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    <System.Diagnostics.DebuggerStepThrough()> _
    Private Sub InitializeComponent()
        Me.TableLayoutPanel1 = New System.Windows.Forms.TableLayoutPanel()
        Me.OK_Button = New System.Windows.Forms.Button()
        Me.Cancel_Button = New System.Windows.Forms.Button()
        Me.Label1 = New System.Windows.Forms.Label()
        Me.TextBox1 = New System.Windows.Forms.TextBox()
        Me.TextBox2 = New System.Windows.Forms.TextBox()
        Me.Label2 = New System.Windows.Forms.Label()
        Me.TextBox3 = New System.Windows.Forms.TextBox()
        Me.Label3 = New System.Windows.Forms.Label()
        Me.TextBox4 = New System.Windows.Forms.TextBox()
        Me.Label4 = New System.Windows.Forms.Label()
        Me.TextBox5 = New System.Windows.Forms.TextBox()
        Me.Label5 = New System.Windows.Forms.Label()
        Me.TextBox6 = New System.Windows.Forms.TextBox()
        Me.Label6 = New System.Windows.Forms.Label()
        Me.TextBox7 = New System.Windows.Forms.TextBox()
        Me.Label7 = New System.Windows.Forms.Label()
        Me.TextBox8 = New System.Windows.Forms.TextBox()
        Me.Label8 = New System.Windows.Forms.Label()
        Me.TextBox9 = New System.Windows.Forms.TextBox()
        Me.Label9 = New System.Windows.Forms.Label()
        Me.TextBox10 = New System.Windows.Forms.TextBox()
        Me.Label10 = New System.Windows.Forms.Label()
        Me.TextBox11 = New System.Windows.Forms.TextBox()
        Me.Label11 = New System.Windows.Forms.Label()
		Me.TextBox12 = New System.Windows.Forms.TextBox()
        Me.Label12 = New System.Windows.Forms.Label()
        Me.TextBox13 = New System.Windows.Forms.TextBox()
        Me.Label13 = New System.Windows.Forms.Label()
		Me.TextBox14 = New System.Windows.Forms.TextBox()
        Me.Label14 = New System.Windows.Forms.Label()
		Me.TextBox15 = New System.Windows.Forms.TextBox()
        Me.Label15 = New System.Windows.Forms.Label()
		Me.TextBox16 = New System.Windows.Forms.TextBox()
        Me.Label16 = New System.Windows.Forms.Label()
		Me.TextBox17 = New System.Windows.Forms.TextBox()
        Me.Label17 = New System.Windows.Forms.Label()
		Me.TextBox18 = New System.Windows.Forms.TextBox()
        Me.Label18 = New System.Windows.Forms.Label()
		Me.TextBox19 = New System.Windows.Forms.TextBox()
        Me.Label19 = New System.Windows.Forms.Label()
		Me.TextBox20 = New System.Windows.Forms.TextBox()
        Me.Label20 = New System.Windows.Forms.Label()
		Me.TextBox21 = New System.Windows.Forms.TextBox()
        Me.Label21 = New System.Windows.Forms.Label()
		Me.TextBox22 = New System.Windows.Forms.TextBox()
        Me.Label22 = New System.Windows.Forms.Label()
		Me.TextBox23 = New System.Windows.Forms.TextBox()
        Me.Label23 = New System.Windows.Forms.Label()
		Me.TextBox24 = New System.Windows.Forms.TextBox()
        Me.Label24 = New System.Windows.Forms.Label()
		Me.TableLayoutPanel1.SuspendLayout()
        Me.SuspendLayout()
        'TableLayoutPanel1
        Me.TableLayoutPanel1.Anchor = CType((System.Windows.Forms.AnchorStyles.Bottom Or System.Windows.Forms.AnchorStyles.Right), System.Windows.Forms.AnchorStyles)
        Me.TableLayoutPanel1.ColumnCount = 2
        Me.TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
        Me.TableLayoutPanel1.Controls.Add(Me.OK_Button, 0, 0)
        Me.TableLayoutPanel1.Controls.Add(Me.Cancel_Button, 1, 0)
        Me.TableLayoutPanel1.Location = New System.Drawing.Point(277, 618) '(277, 332)
        Me.TableLayoutPanel1.Name = "TableLayoutPanel1"
        Me.TableLayoutPanel1.RowCount = 1
        Me.TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 50.0!))
        Me.TableLayoutPanel1.Size = New System.Drawing.Size(146, 29)
        Me.TableLayoutPanel1.TabIndex = 0
        'OK_Button
        Me.OK_Button.Anchor = System.Windows.Forms.AnchorStyles.None
        Me.OK_Button.Location = New System.Drawing.Point(3, 3)
        Me.OK_Button.Name = "OK_Button"
        Me.OK_Button.Size = New System.Drawing.Size(67, 23)
        Me.OK_Button.TabIndex = 0
        Me.OK_Button.Text = "OK"
        'Cancel_Button
        Me.Cancel_Button.Anchor = System.Windows.Forms.AnchorStyles.None
        Me.Cancel_Button.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.Cancel_Button.Location = New System.Drawing.Point(76, 3)
        Me.Cancel_Button.Name = "Cancel_Button"
        Me.Cancel_Button.Size = New System.Drawing.Size(67, 23)
        Me.Cancel_Button.TabIndex = 1
        Me.Cancel_Button.Text = "Cancel"
        'TextBox1
        Me.TextBox1.Location = New System.Drawing.Point(149, 23)
        Me.TextBox1.Name = "TextBox1"
        Me.TextBox1.Size = New System.Drawing.Size(234, 20)
        Me.TextBox1.TabIndex = 2
		'Label1
        Me.Label1.Location = New System.Drawing.Point(9, 19)
        Me.Label1.Name = "Label1"
        Me.Label1.Size = New System.Drawing.Size(134, 26)
        Me.Label1.TabIndex = 1
        Me.Label1.Text = "Attribute:"
        Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox2
        Me.TextBox2.Location = New System.Drawing.Point(149, 49)
        Me.TextBox2.Name = "TextBox2"
        Me.TextBox2.Size = New System.Drawing.Size(234, 20)
        Me.TextBox2.TabIndex = 4
        'Label2
        Me.Label2.Location = New System.Drawing.Point(9, 45)
        Me.Label2.Name = "Label2"
        Me.Label2.Size = New System.Drawing.Size(134, 26)
        Me.Label2.TabIndex = 3
        Me.Label2.Text = "Attribute:"
        Me.Label2.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox3
        Me.TextBox3.Location = New System.Drawing.Point(149, 75)
        Me.TextBox3.Name = "TextBox3"
        Me.TextBox3.Size = New System.Drawing.Size(234, 20)
        Me.TextBox3.TabIndex = 6
        'Label3
        Me.Label3.Location = New System.Drawing.Point(9, 71)
        Me.Label3.Name = "Label3"
        Me.Label3.Size = New System.Drawing.Size(134, 26)
        Me.Label3.TabIndex = 5
        Me.Label3.Text = "Attribute:"
        Me.Label3.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox4
        Me.TextBox4.Location = New System.Drawing.Point(149, 101)
        Me.TextBox4.Name = "TextBox4"
        Me.TextBox4.Size = New System.Drawing.Size(234, 20)
        Me.TextBox4.TabIndex = 8
        'Label4
        Me.Label4.Location = New System.Drawing.Point(9, 97)
        Me.Label4.Name = "Label4"
        Me.Label4.Size = New System.Drawing.Size(134, 26)
        Me.Label4.TabIndex = 7
        Me.Label4.Text = "Attribute:"
        Me.Label4.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox5
        Me.TextBox5.Location = New System.Drawing.Point(149, 127)
        Me.TextBox5.Name = "TextBox5"
        Me.TextBox5.Size = New System.Drawing.Size(234, 20)
        Me.TextBox5.TabIndex = 10
        'Label5
        Me.Label5.Location = New System.Drawing.Point(9, 123)
        Me.Label5.Name = "Label5"
        Me.Label5.Size = New System.Drawing.Size(134, 26)
        Me.Label5.TabIndex = 9
        Me.Label5.Text = "Attribute:"
        Me.Label5.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox6
        Me.TextBox6.Location = New System.Drawing.Point(149, 153)
        Me.TextBox6.Name = "TextBox6"
        Me.TextBox6.Size = New System.Drawing.Size(234, 20)
        Me.TextBox6.TabIndex = 12
        'Label6
        Me.Label6.Location = New System.Drawing.Point(9, 149)
        Me.Label6.Name = "Label6"
        Me.Label6.Size = New System.Drawing.Size(134, 26)
        Me.Label6.TabIndex = 11
        Me.Label6.Text = "Attribute:"
        Me.Label6.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox7
        Me.TextBox7.Location = New System.Drawing.Point(149, 179)
        Me.TextBox7.Name = "TextBox7"
        Me.TextBox7.Size = New System.Drawing.Size(234, 20)
        Me.TextBox7.TabIndex = 14
        'Label7
        Me.Label7.Location = New System.Drawing.Point(9, 175)
        Me.Label7.Name = "Label7"
        Me.Label7.Size = New System.Drawing.Size(134, 26)
        Me.Label7.TabIndex = 13
        Me.Label7.Text = "Attribute:"
        Me.Label7.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox8
        Me.TextBox8.Location = New System.Drawing.Point(149, 205)
        Me.TextBox8.Name = "TextBox8"
        Me.TextBox8.Size = New System.Drawing.Size(234, 20)
        Me.TextBox8.TabIndex = 16
        'Label8
        Me.Label8.Location = New System.Drawing.Point(9, 201)
        Me.Label8.Name = "Label8"
        Me.Label8.Size = New System.Drawing.Size(134, 26)
        Me.Label8.TabIndex = 15
        Me.Label8.Text = "Attribute:"
        Me.Label8.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox9
        Me.TextBox9.Location = New System.Drawing.Point(149, 231)
        Me.TextBox9.Name = "TextBox9"
        Me.TextBox9.Size = New System.Drawing.Size(234, 20)
        Me.TextBox9.TabIndex = 18
        'Label9
        Me.Label9.Location = New System.Drawing.Point(9, 227)
        Me.Label9.Name = "Label9"
        Me.Label9.Size = New System.Drawing.Size(134, 26)
        Me.Label9.TabIndex = 17
        Me.Label9.Text = "Attribute:"
        Me.Label9.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox10
        Me.TextBox10.Location = New System.Drawing.Point(149, 257)
        Me.TextBox10.Name = "TextBox10"
        Me.TextBox10.Size = New System.Drawing.Size(234, 20)
        Me.TextBox10.TabIndex = 20
        'Label10
        Me.Label10.Location = New System.Drawing.Point(9, 253)
        Me.Label10.Name = "Label10"
        Me.Label10.Size = New System.Drawing.Size(134, 26)
        Me.Label10.TabIndex = 19
        Me.Label10.Text = "Attribute:"
        Me.Label10.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox11
        Me.TextBox11.Location = New System.Drawing.Point(149, 283)
        Me.TextBox11.Name = "TextBox11"
        Me.TextBox11.Size = New System.Drawing.Size(234, 20)
        Me.TextBox11.TabIndex = 22
        'Label11
        Me.Label11.Location = New System.Drawing.Point(9, 279)
        Me.Label11.Name = "Label11"
        Me.Label11.Size = New System.Drawing.Size(134, 26)
        Me.Label11.TabIndex = 21
        Me.Label11.Text = "Attribute:"
        Me.Label11.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'TextBox12
        Me.TextBox12.Location = New System.Drawing.Point(149, 309)
        Me.TextBox12.Name = "TextBox12"
        Me.TextBox12.Size = New System.Drawing.Size(234, 20)
        Me.TextBox12.TabIndex = 24
        'Label12
        Me.Label12.Location = New System.Drawing.Point(9, 305)
        Me.Label12.Name = "Label12"
        Me.Label12.Size = New System.Drawing.Size(134, 26)
        Me.Label12.TabIndex = 23
        Me.Label12.Text = "Attribute:"
        Me.Label12.TextAlign = System.Drawing.ContentAlignment.MiddleRight
		' Tot hier OK
        'TextBox13
        Me.TextBox13.Location = New System.Drawing.Point(149, 335)
        Me.TextBox13.Name = "TextBox13"
        Me.TextBox13.Size = New System.Drawing.Size(234, 20)
        Me.TextBox13.TabIndex = 26
        'Label13
        Me.Label13.Location = New System.Drawing.Point(9, 331)
        Me.Label13.Name = "Label13"
        Me.Label13.Size = New System.Drawing.Size(134, 26)
        Me.Label13.TabIndex = 25
        Me.Label13.Text = "Attribute:"
        Me.Label13.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox14
        Me.TextBox14.Location = New System.Drawing.Point(149, 361)
        Me.TextBox14.Name = "TextBox14"
        Me.TextBox14.Size = New System.Drawing.Size(234, 20)
        Me.TextBox14.TabIndex = 28
        'Label14
        Me.Label14.Location = New System.Drawing.Point(9, 357)
        Me.Label14.Name = "Label14"
        Me.Label14.Size = New System.Drawing.Size(134, 26)
        Me.Label14.TabIndex = 27
        Me.Label14.Text = "Attribute:"
        Me.Label14.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox15
        Me.TextBox15.Location = New System.Drawing.Point(149, 387)
        Me.TextBox15.Name = "TextBox13"
        Me.TextBox15.Size = New System.Drawing.Size(234, 20)
        Me.TextBox15.TabIndex = 28
        'Label15
        Me.Label15.Location = New System.Drawing.Point(9, 383)
        Me.Label15.Name = "Label15"
        Me.Label15.Size = New System.Drawing.Size(134, 26)
        Me.Label15.TabIndex = 27
        Me.Label15.Text = "Attribute:"
        Me.Label15.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox16
        Me.TextBox16.Location = New System.Drawing.Point(149, 387)
        Me.TextBox16.Name = "TextBox16"
        Me.TextBox16.Size = New System.Drawing.Size(234, 20)
        Me.TextBox16.TabIndex = 30
        'Label16
        Me.Label16.Location = New System.Drawing.Point(9, 383)
        Me.Label16.Name = "Label16"
        Me.Label16.Size = New System.Drawing.Size(134, 26)
        Me.Label16.TabIndex = 29
        Me.Label16.Text = "Attribute:"
        Me.Label16.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox17
        Me.TextBox17.Location = New System.Drawing.Point(149, 413)
        Me.TextBox17.Name = "TextBox17"
        Me.TextBox17.Size = New System.Drawing.Size(234, 20)
        Me.TextBox17.TabIndex = 32
        'Label17
        Me.Label17.Location = New System.Drawing.Point(9, 409)
        Me.Label17.Name = "Label17"
        Me.Label17.Size = New System.Drawing.Size(134, 26)
        Me.Label17.TabIndex = 31
        Me.Label17.Text = "Attribute:"
        Me.Label17.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox18
        Me.TextBox18.Location = New System.Drawing.Point(149, 439)
        Me.TextBox18.Name = "TextBox18"
        Me.TextBox18.Size = New System.Drawing.Size(234, 20)
        Me.TextBox18.TabIndex = 34
        'Label18
        Me.Label18.Location = New System.Drawing.Point(9, 435)
        Me.Label18.Name = "Label18"
        Me.Label18.Size = New System.Drawing.Size(134, 26)
        Me.Label18.TabIndex = 33
        Me.Label18.Text = "Attribute:"
        Me.Label18.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox19
        Me.TextBox19.Location = New System.Drawing.Point(149, 465)
        Me.TextBox19.Name = "TextBox19"
        Me.TextBox19.Size = New System.Drawing.Size(234, 20)
        Me.TextBox19.TabIndex = 36
        'Label19
        Me.Label19.Location = New System.Drawing.Point(9, 461)
        Me.Label19.Name = "Label19"
        Me.Label19.Size = New System.Drawing.Size(134, 26)
        Me.Label19.TabIndex = 35
        Me.Label19.Text = "Attribute:"
        Me.Label19.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox20
        Me.TextBox20.Location = New System.Drawing.Point(149, 491)
        Me.TextBox20.Name = "TextBox20"
        Me.TextBox20.Size = New System.Drawing.Size(234, 20)
        Me.TextBox20.TabIndex = 38
        'Label20
        Me.Label20.Location = New System.Drawing.Point(9, 487)
        Me.Label20.Name = "Label20"
        Me.Label20.Size = New System.Drawing.Size(134, 26)
        Me.Label20.TabIndex = 37
        Me.Label20.Text = "Attribute:"
        Me.Label20.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox21
        Me.TextBox21.Location = New System.Drawing.Point(149, 517)
        Me.TextBox21.Name = "TextBox21"
        Me.TextBox21.Size = New System.Drawing.Size(234, 20)
        Me.TextBox21.TabIndex = 40
        'Label21
        Me.Label21.Location = New System.Drawing.Point(9, 513)
        Me.Label21.Name = "Label21"
        Me.Label21.Size = New System.Drawing.Size(134, 26)
        Me.Label21.TabIndex = 39
        Me.Label21.Text = "Attribute:"
        Me.Label21.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox22
        Me.TextBox22.Location = New System.Drawing.Point(149, 543)
        Me.TextBox22.Name = "TextBox22"
        Me.TextBox22.Size = New System.Drawing.Size(234, 20)
        Me.TextBox22.TabIndex = 42
        'Label22
        Me.Label22.Location = New System.Drawing.Point(9, 539)
        Me.Label22.Name = "Label22"
        Me.Label22.Size = New System.Drawing.Size(134, 26)
        Me.Label22.TabIndex = 41
        Me.Label22.Text = "Attribute:"
        Me.Label22.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox23
        Me.TextBox23.Location = New System.Drawing.Point(149, 569)
        Me.TextBox23.Name = "TextBox23"
        Me.TextBox23.Size = New System.Drawing.Size(234, 20)
        Me.TextBox23.TabIndex = 44
        'Label23
        Me.Label23.Location = New System.Drawing.Point(9, 565)
        Me.Label23.Name = "Label23"
        Me.Label23.Size = New System.Drawing.Size(134, 26)
        Me.Label23.TabIndex = 43
        Me.Label23.Text = "Attribute:"
        Me.Label23.TextAlign = System.Drawing.ContentAlignment.MiddleRight
       'TextBox24
        Me.TextBox24.Location = New System.Drawing.Point(149, 595)
        Me.TextBox24.Name = "TextBox24"
        Me.TextBox24.Size = New System.Drawing.Size(234, 20)
        Me.TextBox24.TabIndex = 46
        'Label24
        Me.Label24.Location = New System.Drawing.Point(9, 591)
        Me.Label24.Name = "Label24"
        Me.Label24.Size = New System.Drawing.Size(134, 26)
        Me.Label24.TabIndex = 45
        Me.Label24.Text = "Attribute:"
        Me.Label24.TextAlign = System.Drawing.ContentAlignment.MiddleRight
        'Dialog1
        Me.AcceptButton = Me.OK_Button
        Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.CancelButton = Me.Cancel_Button
        Me.ClientSize = New System.Drawing.Size(500, 649)  '(500, 363)
		Me.Controls.Add(Me.TextBox24)
        Me.Controls.Add(Me.Label24)
		Me.Controls.Add(Me.TextBox23)
        Me.Controls.Add(Me.Label23)
		Me.Controls.Add(Me.TextBox22)
        Me.Controls.Add(Me.Label22)
		Me.Controls.Add(Me.TextBox21)
        Me.Controls.Add(Me.Label21)
		Me.Controls.Add(Me.TextBox20)
        Me.Controls.Add(Me.Label20)
		Me.Controls.Add(Me.TextBox19)
        Me.Controls.Add(Me.Label19)
		Me.Controls.Add(Me.TextBox18)
        Me.Controls.Add(Me.Label18)
		Me.Controls.Add(Me.TextBox17)
        Me.Controls.Add(Me.Label17)
		Me.Controls.Add(Me.TextBox16)
        Me.Controls.Add(Me.Label16)
		Me.Controls.Add(Me.TextBox15)
        Me.Controls.Add(Me.Label15)
		Me.Controls.Add(Me.TextBox14)
        Me.Controls.Add(Me.Label14)
		Me.Controls.Add(Me.TextBox13)
        Me.Controls.Add(Me.Label13)
		Me.Controls.Add(Me.TextBox12)
        Me.Controls.Add(Me.Label12)
        Me.Controls.Add(Me.TextBox11)
        Me.Controls.Add(Me.Label11)
        Me.Controls.Add(Me.TextBox10)
        Me.Controls.Add(Me.Label10)
        Me.Controls.Add(Me.TextBox9)
        Me.Controls.Add(Me.Label9)
        Me.Controls.Add(Me.TextBox8)
        Me.Controls.Add(Me.Label8)
        Me.Controls.Add(Me.TextBox7)
        Me.Controls.Add(Me.Label7)
        Me.Controls.Add(Me.TextBox6)
        Me.Controls.Add(Me.Label6)
        Me.Controls.Add(Me.TextBox5)
        Me.Controls.Add(Me.Label5)
        Me.Controls.Add(Me.TextBox4)
        Me.Controls.Add(Me.Label4)
        Me.Controls.Add(Me.TextBox3)
        Me.Controls.Add(Me.Label3)
        Me.Controls.Add(Me.TextBox2)
        Me.Controls.Add(Me.Label2)
        Me.Controls.Add(Me.TextBox1)
        Me.Controls.Add(Me.Label1)
        Me.Controls.Add(Me.TableLayoutPanel1)
        Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog
        Me.MaximizeBox = False
        Me.MinimizeBox = False
        Me.Name = "Dialog1"
        Me.ShowInTaskbar = False
        Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
        Me.Text = "Dialog1"
        Me.TableLayoutPanel1.ResumeLayout(False)
        Me.ResumeLayout(False)
        Me.PerformLayout()
    End Sub
    Friend WithEvents TableLayoutPanel1 As System.Windows.Forms.TableLayoutPanel
    Friend WithEvents OK_Button As System.Windows.Forms.Button
    Friend WithEvents Cancel_Button As System.Windows.Forms.Button
    Friend WithEvents Label1 As System.Windows.Forms.Label
    Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
    Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
    Friend WithEvents Label2 As System.Windows.Forms.Label
    Friend WithEvents TextBox3 As System.Windows.Forms.TextBox
    Friend WithEvents Label3 As System.Windows.Forms.Label
    Friend WithEvents TextBox4 As System.Windows.Forms.TextBox
    Friend WithEvents Label4 As System.Windows.Forms.Label
    Friend WithEvents TextBox5 As System.Windows.Forms.TextBox
    Friend WithEvents Label5 As System.Windows.Forms.Label
    Friend WithEvents TextBox6 As System.Windows.Forms.TextBox
    Friend WithEvents Label6 As System.Windows.Forms.Label
    Friend WithEvents TextBox7 As System.Windows.Forms.TextBox
    Friend WithEvents Label7 As System.Windows.Forms.Label
    Friend WithEvents TextBox8 As System.Windows.Forms.TextBox
    Friend WithEvents Label8 As System.Windows.Forms.Label
    Friend WithEvents TextBox9 As System.Windows.Forms.TextBox
    Friend WithEvents Label9 As System.Windows.Forms.Label
    Friend WithEvents TextBox10 As System.Windows.Forms.TextBox
    Friend WithEvents Label10 As System.Windows.Forms.Label
    Friend WithEvents TextBox11 As System.Windows.Forms.TextBox
    Friend WithEvents Label11 As System.Windows.Forms.Label
	Friend WithEvents TextBox12 As System.Windows.Forms.TextBox
    Friend WithEvents Label12 As System.Windows.Forms.Label
	Friend WithEvents Label13 As System.Windows.Forms.Label
    Friend WithEvents TextBox13 As System.Windows.Forms.TextBox
	Friend WithEvents Label14 As System.Windows.Forms.Label
    Friend WithEvents TextBox14 As System.Windows.Forms.TextBox
	Friend WithEvents Label15 As System.Windows.Forms.Label
    Friend WithEvents TextBox15 As System.Windows.Forms.TextBox
	Friend WithEvents Label16 As System.Windows.Forms.Label
    Friend WithEvents TextBox16 As System.Windows.Forms.TextBox
	Friend WithEvents Label17 As System.Windows.Forms.Label
    Friend WithEvents TextBox17 As System.Windows.Forms.TextBox
	Friend WithEvents Label18 As System.Windows.Forms.Label
    Friend WithEvents TextBox18 As System.Windows.Forms.TextBox
	Friend WithEvents Label19 As System.Windows.Forms.Label
    Friend WithEvents TextBox19 As System.Windows.Forms.TextBox
	Friend WithEvents Label20 As System.Windows.Forms.Label
    Friend WithEvents TextBox20 As System.Windows.Forms.TextBox
	Friend WithEvents Label21 As System.Windows.Forms.Label
    Friend WithEvents TextBox21 As System.Windows.Forms.TextBox
	Friend WithEvents Label22 As System.Windows.Forms.Label
    Friend WithEvents TextBox22 As System.Windows.Forms.TextBox
	Friend WithEvents Label23 As System.Windows.Forms.Label
    Friend WithEvents TextBox23 As System.Windows.Forms.TextBox
	Friend WithEvents Label24 As System.Windows.Forms.Label
    Friend WithEvents TextBox24 As System.Windows.Forms.TextBox
End Class
 https://files.engineering.com/getfile.aspx?folder=e75a93bc-be60-4775-b219-96e4b412b962&file=MCAM_Plastic_StartPart.prt
If you don't know the attribute type apriori, you can use the .GetUserAttribute method and query the type from the returned information; if you do know the type, you can use .GetIntegerUserAttribute or .GetRealUserAttribute. If you only need the value as a string value to display in your dialog, you can use the .GetUserAttributeAsString method to convert the value to a string type.
Note that the code in your link was written for NX 7.5 and the .GetAttribute and .SetAttribute methods have since been marked as obsolete. New methods have been added to get/set attributes; it is recommended that you use the new methods.
www.nxjournaling.com
Hello Cowski,
In the first post, I have added my Template File.
I do know the Attribute Type, it is of Type Number.
It is the only one, i have a this Type, all others are String, so no issues with those.
Can you help me to solve the Attribute issue for myAttributeTitle(10)
Any help, much appreciated!
Pascal
In that case, use the .GetRealUserAttribute method. Pass in the attribute title and index (use -1 for the index if you are not dealing with an array attribute); the method will return the value of the attribute. Something like below (code not tested):
Code:
Dim myValue as Double = myPart.GetRealUserAttribute("theAttributeTitle", -1)
