Attention MS Access Aces 1
macduff
hello,
I need some help with auto numbering. Is there a way to change the format from 1,2,3,4,5 etc.....to 000001,000002,000003,000004,000005 etc.....
I tried messing with some of the property boxes, but had no luck. Is a character that I need to add? like ie....' * # %
See attached, and thank you!
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 Windows 7 Pro (64-bit)
Xeon CPU 2.53 GHz 6.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
thanks cbl. same username and password as eng-tips?
Mechanical Designer
No. You can use the same if you want, but you have to register separately. E-T & T-T use separate member databases.
Eric,
Thanks so much! It's very simple to do.
Mechanical Designer
