ATEX certification
vjr0512
IN
In one of the Offshore project, for a package we have used ATEX certified Temperature transmitters of with dual certification of Exd and EXia. The thermowell assembly has been certified for Exd. The Package supplier had used ATEX certified Exd Cable adapters (90 Deg) to facilitate cable routing as there was limited accessibility.
Now client is asking us to provide an Atex certificate where in it should specifically mention about the use of adapters i.e they want an ATEX certificate for the combined item ( Thermowell + adapter). Is this a normal practice to provide such ATEX certification? The package supplier has informed that NO such certification is possible and not normally tested for ATEX certification.
Thanks to confirm whether such combined certifications are available as per Client request? Whether the use of such ATEX certified adapters do VOID the ATEX certification of the Instruments?
I'm not aware of adaptors requiring any additional certification over the normal Ex'd' markings. Obviously they need to be used with an Ex'd' gland, and you can't nest adaptors one inside another. Might be worth a quick call to the manufacturer of the adaptor - Hawke, Raxton, or whoever.
"Now client is asking us to provide an Atex certificate where in it should specifically mention about the use of adapters i.e they want an ATEX certificate for the combined item"
That seems a bit silly. Are you then supposed to use uncertified equipment? Is ATEX certification of an adaptor even useful in a non-ATEX application? Otherwise, there wouldn't be much point in certification if every combination of components is only certified in aggregate. That would be expensive and wasteful. Surely, it makes sense that certified components, so long as they meet their interface requirements, are compatible and are compliant to ATEX requirements without requiring additional testing or certification.
see Article 2 of the directive:
1. Member States shall take all appropriate measures to ensure that the equipment, protective systems and devices referred to in Article 1 (2) to which this Directive applies may be placed on the market and put into service only if, when properly installed and maintained and used for their intended purpose, they do not endanger the health and safety of persons and, where appropriate, domestic animals or property.
And Article 5 of the directive:
1. Member States shall regard as conforming to all the provisions of this Directive, including the relevant conformity assessment procedures laid down in chapter II: -- the components referred to in Article 4 (2), accompanied by the certificate of conformity referred to in Article 8 (3).
And Article 8:
3. The procedures referred to in paragraph 1 shall be applied in respect of components as referred to in Article 4 (2), with the exception of the affixing of the CE marking. A certificate shall be issued by the manufacturer or his authorized representative established in the Community, declaring the conformity of the components with the provisions of this Directive which apply to them and stating their characteristics and how they must be incorporated into equipment or protective systems to assist compliance with the essential requirements applicable to finished equipment or protective systems.
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com:
