Hold on Ken, those are two different tests, designed to find two different things. They just happen to both use FeCl3.
The A923 must be preformed on a freshly ground surface with no pickle or passivation. You are strictly looking for intermetallics.
The G48 is a pitting test, so not pits means that you pass. G48 A is a 72 hour test though, so it makes me wonder, did they really do a Method E.
The other not so slight difference is that G48 C, D, E, F and A923 all use an aicdified solution. G48 A and B use straight FeCl3.
Converting the units is also a pain. Whoever thought that 10 mg/dm2/day was cute need to be kicked. I guess that converts to 1g/m2/day or 0.1mg/cm2/day. This makes your 0.2g/m2 not bad at all.
Ask to see their procedure outlining the test method. Ask to see the coupons. My hunch is that they are not sure what they did.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
