MikeAbuhatoum
Industrial
thread330-208382
Thank you all for starting this thread, unfortunately B7 & B7M are the most common products in our business but there is not much of information in the ASTM A193spec itself to help you with heat treating your 4140,4142,4145 to B7, however I believe there are few AMS specs that cover the process, anyway we do the mentioned process in a daily basis and it is OR "at least What we do":
1- Austenitize to 1550/1600 for up to 60 Minuets, but never less than 30 minuets.
2- Quench is Mar heated oil.
3- Temper" Immediately after quenching" for another hour( Generally 45-60 Minuets).
4- Thread Roll.......and in some cases we start with thread rolling the product followed by austenitizing, quenching, and tempering.
As long you austenitie, quench, temper.....It is all about timing, and temperature which is easily controlled ! We have never had an issue with this process and I doubt we will ever do.
Best of luck.
Mike Abuhatoum.
Best of luck.
Mike Abuhatoum.
