assigning spring in local axis
amghma
JO
hi all ,
I would to share with you an issue that I have faced in ETABS while assigning spring stiffness for joint, I need to assign spring stiffness in the -x but i cant assign -ve stiffness value, what are the alternative options to do so ?
please find the attached shot from ETABS.
thanks in advance
 https://files.engineering.com/getfile.aspx?folder=7729b3e0-2359-46a2-a147-2673a27d5099&file=spring_local.JPG
Why would you need a skew spring?
Springs are tensors and their transformation to another (skew) coordinate system is not a simple task.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
