Assign Attributes for each Assembly Part are not saved
allanareque
Industrial
BR
Hello everybody.
I started a Journal that allows you to enter six attributes at once for all components of an assembly.
This Journal is the result of the union of several works by colleagues from the forum who always collaborate with the development of our work with UGNX.
However, this Journal has a problem: It collects the input information of the attributes from the Windows Form and writes them as attributes to each Part File through NXJ_Assembly_info 0.1.1 but, when closing the assembly and opening it again, everything is loses. Each File part does not write the attributes that were written.
This occurs even using the "Save All" command.
I noticed that the same Journals that use NXJ_Assembly_info have the same problem.
Has anyone encountered this same problem and already has a solution for it? If anyone knows what is happening, please share the solution to this problem.
I'll leave the code I'm working on here so you can check what might be wrong and ask you to change it in order to make it save the attributes in each Part file.
I believe that this Journal can also help other people in their activities, so I make it available here.
Thank you very much.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module Module1
    Private _formTitle As String = ""
    Public ReadOnly Property FormTitle() As String
        Get
            Return _formTitle
        End Get
    End Property
    Private _attributeTitle As String = ""
    Public ReadOnly Property AttributeTitle() As String
        Get
            Return _attributeTitle
        End Get
    End Property
    Private _attributeBO As String = ""
    Public Property AttributeBO() As String
        Get
            Return _attributeBO
        End Get
        Set(ByVal value As String)
            _attributeBO = value
        End Set
    End Property
    Private _attributeCodigoProduto As String = ""
    Public Property AttributeCodigoProduto() As String
        Get
            Return _attributeCodigoProduto
        End Get
            _attributeCodigoProduto = value
        End Set
    End Property
    Private _attributeFerramenta As String = ""
    Public Property AttributeFerramenta() As String
        Get
            Return _attributeFerramenta
        End Get
            _attributeFerramenta = value
        End Set
    End Property
    Private _attributeNomeProduto As String = ""
    Public Property AttributeNomeProduto() As String
        Get
            Return _attributeNomeProduto
        End Get
            _attributeNomeProduto = value
        End Set
    End Property
    Private _attributeProjectDate As String = ""
    Public Property AttributeProjectDate() As String
        Get
            Return _attributeProjectDate
        End Get
            _attributeProjectDate = value
        End Set
    End Property
    Private _attributeProjectName As String = ""
    Public Property AttributeProjectName() As String
        Get
            Return _attributeProjectName
        End Get
            _attributeProjectName = value
        End Set
    End Property
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Dim blnCancel As Boolean = False
    Sub Main()
 Dim myAsmInfo As New NXJ_Assembly_info
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim lg As LogFile = theSession.LogFile
        Const undoMarkName As String = "NXJ form journal"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim myAttributeInfo As NXObject.AttributeInformation
        _attributeTitle = "BO"
        Try
            myAttributeInfo = workPart.GetUserAttribute(_attributeTitle, NXObject.AttributeType.String, -1) 'recolhe a informacao ja existente de um atributo
            _attributeBO = myAttributeInfo.StringValue
        Catch ex As NXException
            If ex.ErrorCode = 512008 Then
                'attribute not found
            Else
                'unexpected error: show error message, undo, and exit journal
                MsgBox(ex.ErrorCode & ": " & ex.Message)
                theSession.UndoToMark(markId1, undoMarkName)
                Return
            End If
        Finally
        End Try
        _attributeTitle = "Codigo_Produto"
        Try
            _attributeCodigoProduto = myAttributeInfo.StringValue
            Else
                Return
            End If
        Finally
        End Try
        _attributeTitle = "Ferramenta"
        Try
            _attributeFerramenta = myAttributeInfo.StringValue
            Else
                Return
            End If
        Finally
        End Try
        _attributeTitle = "Nome_Produto"
        Try
            _attributeNomeProduto = myAttributeInfo.StringValue
            Else
                Return
            End If
        Finally
        End Try
        _attributeTitle = "Project_Date"
        Try
            _attributeProjectDate = myAttributeInfo.StringValue
            Else
                Return
            End If
        Finally
        End Try
        _attributeTitle = "Project_Name"
        Try
            _attributeProjectName = myAttributeInfo.StringValue
            Else
                Return
            End If
        Finally
        End Try
        _formTitle = "Preenchimento Carimbo 2D"
        Dim myForm As New Form1
        'set form object properties (current part attribute title and value)
        myForm.AttributeBO =  _attributeBO
        myForm.AttributeCodigoProduto =  _attributeCodigoProduto
        myForm.AttributeFerramenta = _attributeFerramenta
        myForm.AttributeNomeProduto = _attributeNomeProduto
        myForm.AttributeProjectDate =  _attributeProjectDate
        myForm.AttributeProjectName = _attributeProjectName
        myForm.FormTitle = _formTitle
        'display our form
        ufs.Abort.DisableAbort()
        myForm.ShowDialog()
'----------------------------ACAO APOS INPUTS--------------------------------------------------
       Try
            myAsmInfo.Part = workPart
            MessageBox.Show("Error: " & ex.Message & ControlChars.CrLf & "journal exiting", "Error " & ex.ErrorCode.ToString, MessageBoxButtons.OK, MessageBoxIcon.Error)
            Return
       End Try
        '----Adicione aqui-----------------
        Dim attTitleBO As String = "BO"
        Dim attTitleCodigoProduto As String = "Codigo_Produto"
        Dim attTitleFerramenta As String = "Ferramenta"
        Dim attTitleNomeProduto As String = "Nome_Produto"
        Dim attTitleProjectDate As String = "Project_Date"
        Dim attTitleProjectName As String = "Project_BO"
        Dim attValueBO As String = ""
        Dim attValueCodigoProduto As String = ""
        Dim attValueFerramenta As String = ""
        Dim attValueNomeProduto As String = ""
        Dim attValueProjectDate As String = ""
        Dim attValueProjectName As String = ""
        attValueBO = _attributeBO
        attValueCodigoProduto = _attributeCodigoProduto
        attValueFerramenta = _attributeFerramenta
        attValueNomeProduto = _attributeNomeProduto
        attValueProjectDate = _attributeProjectDate
        attValueProjectName = _attributeProjectName
        workPart.SetAttribute(attTitleBO, attValueBO)
        workPart.SetAttribute(attTitleCodigoProduto, attValueCodigoProduto)
        workPart.SetAttribute(attTitleFerramenta, attValueFerramenta)
        workPart.SetAttribute(attTitleNomeProduto, attValueNomeProduto)
        workPart.SetAttribute(attTitleProjectDate, attValueProjectDate)
        workPart.SetAttribute(attTitleProjectName, attValueProjectName)
        workPart.SetUserAttribute("BO", -1, myForm.AttributeBO, Update.Option.Later)
        workPart.SetUserAttribute("Codigo_Produto", -1, myForm.AttributeCodigoProduto, Update.Option.Later)
        workPart.SetUserAttribute("Ferramenta", -1, myForm.AttributeFerramenta, Update.Option.Later)
        workPart.SetUserAttribute("Nome_Produto", -1, myForm.AttributeNomeProduto, Update.Option.Later)
        workPart.SetUserAttribute("Project_Date", -1, myForm.AttributeProjectDate, Update.Option.Later)
        workPart.SetUserAttribute("Project_Name", -1, myForm.AttributeProjectName, Update.Option.Later)
       For Each myPart As Part In myAsmInfo.AllUniqueParts
            myPart.SetAttribute("BO", myForm.AttributeBO)
            myPart.SetAttribute("Codigo_Produto", myForm.AttributeCodigoProduto)
            myPart.SetAttribute("Ferramenta", myForm.AttributeFerramenta)
            myPart.SetAttribute("Nome_Produto", myForm.AttributeNomeProduto)
            myPart.SetAttribute("Project_Date", myForm.AttributeProjectDate)
            myPart.SetAttribute("Project_Name", myForm.AttributeProjectName)
        Next
    End Sub
End Module
'--------------------FINAL DO MODULO PRINCIPAL--------------------------------------------------
Public Class Form1
    Private _frmTitle As String
    Public Property FormTitle() As String
        Get
            Return _frmTitle
        End Get
            _frmTitle = value
        End Set
    End Property
    Private _frmAttributeTitle As String
    Public Property AttributeTitle() As String
        Get
            Return _frmAttributeTitle
        End Get
            _frmAttributeTitle = value
        End Set
    End Property
    Private _frmAttributeBO As String
        Get
            Return _frmAttributeBO
        End Get
            _frmAttributeBO = value
        End Set
    End Property
    Private _frmAttributeCodigoProduto As String
        Get
            Return _frmAttributeCodigoProduto
        End Get
            _frmAttributeCodigoProduto = value
        End Set
    End Property
    Private _frmAttributeFerramenta As String
        Get
            Return _frmAttributeFerramenta
        End Get
            _frmAttributeFerramenta = value
        End Set
    End Property
    Private _frmAttributeNomeProduto As String
        Get
            Return _frmAttributeNomeProduto
        End Get
            _frmAttributeNomeProduto = value
        End Set
    End Property
    Private _frmAttributeProjectDate As String
        Get
            Return _frmAttributeProjectDate
        End Get
            _frmAttributeProjectDate = value
        End Set
    End Property
    Private _frmAttributeProjectName As String
        Get
            Return _frmAttributeProjectName
        End Get
            _frmAttributeProjectName = value
        End Set
    End Property
    Private _canceled As Boolean = False
    Public ReadOnly Property Canceled() As Boolean
        Get
            Return _canceled
        End Get
    End Property
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Me.Text = _frmTitle
        TextBox_BO.Text = _frmAttributeBO
        TextBox_CodigoProduto.Text = _frmAttributeCodigoProduto
        TextBox_Ferramenta.Text = _frmAttributeFerramenta
        TextBox_NomeProduto.Text = _frmAttributeNomeProduto
        TextBox_ProjectDate.Text = _frmAttributeProjectDate
        TextBox_ProjectName.Text = _frmAttributeProjectName
    End Sub
    Private Sub btnCancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnCancel.Click
        _canceled = True
        Me.Close()
    End Sub
    Private Sub btnOK_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnOK.Click
        _frmAttributeBO = TextBox_BO.Text.ToUpper
        _frmAttributeCodigoProduto = TextBox_CodigoProduto.Text.ToUpper
        _frmAttributeFerramenta = TextBox_Ferramenta.Text.ToUpper
        _frmAttributeNomeProduto = TextBox_NomeProduto.Text.ToUpper
        _frmAttributeProjectDate = TextBox_ProjectDate.Text.ToUpper
        _frmAttributeProjectName = TextBox_ProjectName.Text.ToUpper
        Me.Close()
    End Sub
End Class
'----------windows form------------------------------------------------------
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Form1
    Inherits System.Windows.Forms.Form
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()> _
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    <System.Diagnostics.DebuggerStepThrough()> _
    Private Sub InitializeComponent()
        Me.btnOK = New System.Windows.Forms.Button()
        Me.btnCancel = New System.Windows.Forms.Button()
        Me.Label1 = New System.Windows.Forms.Label()
        Me.Label2 = New System.Windows.Forms.Label()
        Me.Label3 = New System.Windows.Forms.Label()
        Me.Label4 = New System.Windows.Forms.Label()
        Me.Label5 = New System.Windows.Forms.Label()
        Me.Label6 = New System.Windows.Forms.Label()
        Me.TextBox_BO = New System.Windows.Forms.TextBox()
        Me.TextBox_Ferramenta = New System.Windows.Forms.TextBox()
        Me.TextBox_NomeProduto = New System.Windows.Forms.TextBox()
        Me.TextBox_CodigoProduto = New System.Windows.Forms.TextBox()
        Me.TextBox_ProjectName = New System.Windows.Forms.TextBox()
        Me.TextBox_ProjectDate = New System.Windows.Forms.TextBox()
        Me.SuspendLayout()
        'btnOK
        Me.btnOK.Location = New System.Drawing.Point(82, 200)
        Me.btnOK.Name = "btnOK"
        Me.btnOK.Size = New System.Drawing.Size(75, 23)
        Me.btnOK.TabIndex = 7
        Me.btnOK.Text = "OK"
        Me.btnOK.UseVisualStyleBackColor = True
        'btnCancel
        Me.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.btnCancel.Location = New System.Drawing.Point(177, 200)
        Me.btnCancel.Name = "btnCancel"
        Me.btnCancel.Size = New System.Drawing.Size(75, 23)
        Me.btnCancel.TabIndex = 8
        Me.btnCancel.Text = "Cancel"
        Me.btnCancel.UseVisualStyleBackColor = True
        'Label1 'Textos de identificacao
        Me.Label1.AutoSize = True
        Me.Label1.Location = New System.Drawing.Point(12, 22)
        Me.Label1.Name = "Label1"
        Me.Label1.Size = New System.Drawing.Size(38, 13)
        Me.Label1.TabIndex = 0
        Me.Label1.Text = "BO"
        Me.Label1.UseMnemonic = False
        'Label2
        Me.Label2.AutoSize = True
        Me.Label2.Location = New System.Drawing.Point(12, 48)
        Me.Label2.Name = "Label2"
        Me.Label2.Size = New System.Drawing.Size(58, 13)
        Me.Label2.TabIndex = 0
        Me.Label2.Text = "Ferramenta"
        'Label3
        Me.Label3.AutoSize = True
        Me.Label3.Location = New System.Drawing.Point(12, 74)
        Me.Label3.Name = "Label3"
        Me.Label3.Size = New System.Drawing.Size(43, 13)
        Me.Label3.TabIndex = 0
        Me.Label3.Text = "Nome do produto"
        'Label4
        Me.Label4.AutoSize = True
        Me.Label4.Location = New System.Drawing.Point(12, 99)
        Me.Label4.Name = "Label4"
        Me.Label4.Size = New System.Drawing.Size(51, 13)
        Me.Label4.TabIndex = 0
        Me.Label4.Text = "Codigo do produto"
        'Label5
        Me.Label5.AutoSize = True
        Me.Label5.Location = New System.Drawing.Point(12, 125)
        Me.Label5.Name = "Label5"
        Me.Label5.Size = New System.Drawing.Size(37, 13)
        Me.Label5.TabIndex = 0
        Me.Label5.Text = "Projetista"
        'Label6
        Me.Label6.AutoSize = True
        Me.Label6.Location = New System.Drawing.Point(12, 151)
        Me.Label6.Name = "Label6"
        Me.Label6.Size = New System.Drawing.Size(37, 13)
        Me.Label6.TabIndex = 0
        Me.Label6.Text = "Data do projeto"
        'TextBox_BO
        Me.TextBox_BO.Location = New System.Drawing.Point(112, 22)
        Me.TextBox_BO.Name = "TextBox_BO"
        Me.TextBox_BO.Size = New System.Drawing.Size(149, 20)
        Me.TextBox_BO.TabIndex = 1
        'TextBox_Ferramenta
        Me.TextBox_Ferramenta.Location = New System.Drawing.Point(112, 48) 'posicao xy caixa texto entrada
        Me.TextBox_Ferramenta.Name = "TextBox_Ferramenta"
        Me.TextBox_Ferramenta.Size = New System.Drawing.Size(149, 20)
        Me.TextBox_Ferramenta.TabIndex = 2
        'TextBox_NomeProduto
        Me.TextBox_NomeProduto.Location = New System.Drawing.Point(112, 74)
        Me.TextBox_NomeProduto.Name = "TextBox_NomeProduto"
        Me.TextBox_NomeProduto.Size = New System.Drawing.Size(149, 20)
        Me.TextBox_NomeProduto.TabIndex = 3
        'TextBox_CodigoProduto
        Me.TextBox_CodigoProduto.Location = New System.Drawing.Point(112, 99)
        Me.TextBox_CodigoProduto.Name = "TextBox_CodigoProduto"
        Me.TextBox_CodigoProduto.Size = New System.Drawing.Size(149, 20)
        Me.TextBox_CodigoProduto.TabIndex = 4
        'TextBox_ProjectName
        Me.TextBox_ProjectName.Location = New System.Drawing.Point(112, 125)
        Me.TextBox_ProjectName.Name = "TextBox_ProjectName"
        Me.TextBox_ProjectName.Size = New System.Drawing.Size(149, 20)
        Me.TextBox_ProjectName.TabIndex = 5
        'TextBox_ProjectDate
        Me.TextBox_ProjectDate.Location = New System.Drawing.Point(112, 151)
        Me.TextBox_ProjectDate.Name = "TextBox_ProjectDate"
        Me.TextBox_ProjectDate.Size = New System.Drawing.Size(149, 20)
        Me.TextBox_ProjectDate.TabIndex = 6
        'Form1 Formato caixa de dialogo
        Me.AcceptButton = Me.btnOK
        Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!) 'escala xy da janela (quanto mior o valor, menor a jnela)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.CancelButton = Me.btnCancel
        Me.ClientSize = New System.Drawing.Size(337, 231) 'tamanho XY da janela
        Me.Controls.Add(Me.btnOK)
        Me.Controls.Add(Me.btnCancel)
        Me.Controls.Add(Me.TextBox_BO)
        Me.Controls.Add(Me.TextBox_Ferramenta)
        Me.Controls.Add(Me.TextBox_NomeProduto)
        Me.Controls.Add(Me.TextBox_CodigoProduto)
        Me.Controls.Add(Me.TextBox_ProjectName)
        Me.Controls.Add(Me.TextBox_ProjectDate)
        Me.Controls.Add(Me.Label6)
        Me.Controls.Add(Me.Label5)
        Me.Controls.Add(Me.Label4)
        Me.Controls.Add(Me.Label3)
        Me.Controls.Add(Me.Label2)
        Me.Controls.Add(Me.Label1)
        Me.MaximizeBox = False
        Me.MinimizeBox = False
        Me.Name = "Form1"
        Me.SizeGripStyle = System.Windows.Forms.SizeGripStyle.Hide
        Me.Text = "Menu"
        Me.ResumeLayout(False)
        Me.PerformLayout()
        Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent
    End Sub
    Friend WithEvents btnOK As System.Windows.Forms.Button
    Friend WithEvents btnCancel As System.Windows.Forms.Button
    Friend WithEvents Label1 As System.Windows.Forms.Label
    Friend WithEvents Label2 As System.Windows.Forms.Label
    Friend WithEvents Label3 As System.Windows.Forms.Label
    Friend WithEvents Label4 As System.Windows.Forms.Label
    Friend WithEvents Label5 As System.Windows.Forms.Label
    Friend WithEvents Label6 As System.Windows.Forms.Label
    Friend WithEvents TextBox_BO As System.Windows.Forms.TextBox
    Friend WithEvents TextBox_Ferramenta As System.Windows.Forms.TextBox
    Friend WithEvents TextBox_NomeProduto As System.Windows.Forms.TextBox
    Friend WithEvents TextBox_CodigoProduto As System.Windows.Forms.TextBox
    Friend WithEvents TextBox_ProjectName As System.Windows.Forms.TextBox
    Friend WithEvents TextBox_ProjectDate As System.Windows.Forms.TextBox
End Class
'------------------------------------Programa de leitor de informacoes--------------------------------
Public Class NXJ_Assembly_info
#Region "Private Variables"
    Private Const Version As String = "0.1.1"
    Private _theSession As Session = Session.GetSession()
    Private _theUfSession As UFSession = UFSession.GetUFSession
    Private _components As New List(Of Assemblies.Component)
    Private _uniqueParts As New List(Of Part)
    Private _allComponents As New List(Of Assemblies.Component)
    Private _allUniqueParts As New List(Of Part)
    Private _notLoaded As New List(Of String)
    Private lg As LogFile = _theSession.LogFile
#End Region
#Region "Properties"
    Private _isTCRunning As Boolean
    Public ReadOnly Property IsTCRunning() As Boolean
        Get
            Return _isTCRunning
        End Get
    End Property
    Private _thePart As Part = Nothing
    Public Property Part() As Part
        Get
            Return _thePart
        End Get
        Set(ByVal value As Part)
            _thePart = value
            'Me.GetInfo()
            Me.GetAllInfo()
        End Set
    End Property
    Public ReadOnly Property AllComponents() As List(Of Component)
        Get
            Return _allComponents
        End Get
    End Property
    Public ReadOnly Property AllUniqueParts() As List(Of Part)
        Get
            Return _allUniqueParts
        End Get
    End Property
    Public ReadOnly Property Components As List(Of Component)
        Get
            Return _components
        End Get
    End Property
    Public ReadOnly Property UniqueParts As List(Of Part)
        Get
            Return _uniqueParts
        End Get
    End Property
    Public ReadOnly Property NotLoaded As List(Of String)
        Get
            Return _notLoaded
        End Get
    End Property
#End Region
    Public Sub New()
        lg.WriteLine("")
        lg.WriteLine("~ NXJournaling.com: NXJ_Assembly_info object created ~")
        lg.WriteLine("  ~~ Version: " & Version & " ~~")
        lg.WriteLine("  ~~ Timestamp of run: " & DateTime.Now.ToString & " ~~")
        lg.WriteLine("NXJ_Assembly_info Sub New()")
        'determine if we are running under TC or native
        _theUfSession.UF.IsUgmanagerActive(_isTCRunning)
        lg.WriteLine("IsTcRunning: " & _isTCRunning.ToString)
        lg.WriteLine("exiting Sub New")
        lg.WriteLine("")
    End Sub
    Private Sub GetAllInfo()
        'get all component info from assembly (all levels)
        lg.WriteLine("Sub GetAllInfo()")
        Try
            Dim c As ComponentAssembly = Part.ComponentAssembly
            If Not IsNothing(c.RootComponent) Then
                '*** insert code to process 'root component' (assembly file)
                lg.WriteLine("  part has components")
                '*** end of code to process root component
                lg.WriteLine("  calling GetAllComponentChildren")
                GetAllComponentChildren(c.RootComponent)
            Else
                '*** insert code to process piece part, part has no components
                lg.WriteLine("  part has no components")
            End If
            lg.WriteLine("Sub GetAllInfo error: " & ex.ErrorCode)
            lg.WriteLine("  " & ex.Message)
        End Try
        lg.WriteLine("exiting Sub GetAllInfo()")
    End Sub
    Private Sub GetAllComponentChildren(ByVal comp As Component)
        For Each child As Component In comp.GetChildren()
            lg.WriteLine(child.DisplayName)
            '*** insert code to process component or subassembly
            If Me.LoadComponent(child) Then
                _allComponents.Add(child)
                Dim tempPart As Part = child.Prototype.OwningPart
                If Not _allUniqueParts.Contains(tempPart) Then
                    _allUniqueParts.Add(tempPart)
                End If
            Else
                'component could not be loaded
            End If
            '*** end of code to process component or subassembly
            If child.GetChildren.Length <> 0 Then
                '*** this is a subassembly, add code specific to subassemblies
                '*** end of code to process subassembly
            Else
                'this component has no children (it is a leaf node)
                'add any code specific to bottom level components
            End If
            Me.GetAllComponentChildren(child)
        Next
    End Sub
    Private Sub GetInfo()
        'get top level component info from assembly (no recursion)
        lg.WriteLine("Sub GetInfo()")
        Try
                lg.WriteLine("  calling GetComponentChildren")
                Me.GetComponentChildren(c.RootComponent)
            Else
            End If
            lg.WriteLine("Sub GetInfo error: " & ex.ErrorCode)
        End Try
        lg.WriteLine("exiting GetInfo()")
    End Sub
    Private Sub GetComponentChildren(ByVal comp As Component)
            _components.Add(child)
            If Not _uniqueParts.Contains(tempPart) Then
                _uniqueParts.Add(tempPart)
            End If
            Else
            End If
        Next
    End Sub
    Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        lg.WriteLine("Sub LoadComponent()")
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
            End If
            lg.WriteLine("  component: " & theComponent.DisplayName & " is already partially or fully loaded")
            lg.WriteLine("  return: True")
            lg.WriteLine("exiting Sub LoadComponent()")
            lg.WriteLine("")
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                lg.WriteLine("  component not loaded, retrieving part information")
                _theUfSession.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
                lg.WriteLine("  component part file: " & partName)
                Dim theLoadStatus As PartLoadStatus
                _theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    If theLoadStatus.NumberUnloadedParts > 1 Then
                        lg.WriteLine("  problem loading " & theLoadStatus.NumberUnloadedParts.ToString & " components")
                    Else
                        lg.WriteLine("  problem loading 1 component")
                    End If
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        lg.WriteLine("part name: " & theLoadStatus.GetPartName(i))
                        lg.WriteLine("part status: " & theLoadStatus.GetStatus(i))
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            allReadOnly = False
                            If Not _notLoaded.Contains(partName) Then
                                _notLoaded.Add(partName)
                            End If
                        End If
                        lg.WriteLine("status description: " & theLoadStatus.GetStatusDescription(i))
                        lg.WriteLine("")
                    Next
                    If allReadOnly Then
                        lg.WriteLine("  read-only warnings only")
                        Return True
                    Else
                        'warnings other than read-only...
                        lg.WriteLine("  return: False")
                        lg.WriteLine("")
                        Return False
                    End If
                Else
                    lg.WriteLine("  component(s) loaded successfully")
                    lg.WriteLine("")
                    Return True
                End If
            Catch ex2 As NXException
                lg.WriteLine("  Load error: " & ex2.Message)
                lg.WriteLine("  error code: " & ex2.ErrorCode)
                lg.WriteLine("")
                If ex2.Message.ToLower = "file not found" Then
                    End If
                End If
                Return False
            End Try
            lg.WriteLine("  Error in Sub LoadComponent: " & ex.Message)
            lg.WriteLine("")
            Return False
        End Try
    End Function
End Class]
Newer versions of NX added a new assembly load option, "minimal", and set it as the default. However, if you want to modify a part, it must be fully loaded. Two possible solutions to your issue are:
[ol 1]
[li]Change your assembly load option to "load fully" before opening your assembly. This will ensure the parts are ready for processing.[/li]
[li]Load the part fully in your code before assigning the attribute (see code snippet below).[/li]
[/ol]
Code:
For Each tempPart As Part In myAsmInfo.AllUniqueParts
    tempPart.LoadThisPartFully()
    tempPart.SetUserAttribute("TEST", -1, "test value", Update.Option.Now)
Next
The NXJ assembly info code looks for unloaded parts and attempts to load them. If the part reports that it is loaded, whether fully, partially, or minimally, it moves on and does not attempt to change the status. In this regard, to borrow a phrase from GTAC, it is "working as designed". However, I think it would be a good enhancement to add an option to load the parts fully. I will look into making that modification in the near future.
www.nxjournaling.com
Your recommendation worked. That's exactly what was happening: the parts weren't fully loading and the change you proposed made each part load fully able to write code.
Below I'm posting part of the Diary with the change for those who want to improve.
I will try to study what can be taken from this Journal, as I believe they have useless lines running. But so far I haven't found it...
If you want to increase other improvements as mentioned, it will be very welcome and useful to all.
Try
Return
End Try
tempPart.SetUserAttribute("BO", -1, myForm.AttributeBO, Update.Option.Now)
tempPart.SetUserAttribute("Codigo_Produto", -1, myForm.AttributeCodigoProduto, Update.Option.Now)
tempPart.SetUserAttribute("Ferramenta", -1, myForm.AttributeFerramenta, Update.Option.Now)
tempPart.SetUserAttribute("Nome_Produto", -1, myForm.AttributeNomeProduto, Update.Option.Now)
tempPart.SetUserAttribute("Project_Date", -1, myForm.AttributeProjectDate, Update.Option.Now)
tempPart.SetUserAttribute("Project_Name", -1, myForm.AttributeProjectName, Update.Option.Now)
Next
End Sub
End Module
Allan Areque)
Mechanical Designer
UG/NX 10, Wind 10
