I would like to create an assembly between two tubes but I don't know how to do.
I created a simple analysis with two tubes and I would like to create an assembly as if the two tubes was a unique part.The tubes are aligned according their longitudinal axis and there is a small gap between them. I have to create a contact between two circular area.
I tried to couple the DOFs,I have a good result on displacement but the Maximum equivalent Von Mises stress are not good. I tried to use contact manager but I have rigid body motion because of the gap.
To sum up, I would like the tubes assembly gives the same result as one tube with the same length.
Thank you for your Help,
Mickaël
Mickaël
