Hi
When I constrain two pins to to holes say the distance between holes is 100.00000
and the distance between the pins is 100.00001 NX refuse to apply it.
Is there a setting that I can use so the constraint will be applied. (without distance changing)
(for example tolerance control or something else)
Thank you in advanced.
