ASME Y14.5-1994 Assumed 90 degree angle on the print
JsTyLz
Automotive
RO
Under the ASME Y14.5-1994 - Is there anything relating the appearance of all right angles as 90 degrees. I have been told that you must assume that all right angles are 90 degrees.
1. Is it true under the ASME standard I posted?
2. Furthermore, do you assume the title block tolerance on that 90 degree angle??
Thanks in advance
Take a look to see if this answers your question thread1103-192522
KENAT, probably the least qualified checker you'll ever meet...
Yes, fundamental rule 1.4(i) says this very thing, If you have a standard handy, it's on page 4. A more in-depth explanation is on 2.1.1.2 on page 23.
Powerhound
Production Supervisor
Inventor 11
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Thanks for the posts!! Thats all I needed
