andrespastor1987
Nuclear
Hello
I need your help to solve a discussion. I am working in the fabrication of a pressure vessel under ASME VIII Division 1. The cylindrical shell have a thickness (1/2 in.) and material that not require impact test by UCS-66. However the hemispherical head have a thickness (1 in.) that require impact test by UCS-66. The two parts are welded by a tapered joint, where the weld thickness is 1/2 in. In this case, the governing thickness is 1/2 in.. Do the rules of UCS-67 require qualification with impact testing of the WPS to be used for welding of two parts if neither material require impact test in this governing thickness (1/2 in.)? Many thanks and excuse me by my english. It is not my native idiom.
