I am wondering if areas under B31.3 jurisdiction will allow ASME Section VIII Division 1 vessels or other components in the pipeline with no further analysis on the component beyond that as required by Section VIII.
I know for "unlisted components" B31.3 directs you to ASME Section VIII Division 2.
To put this question in context. I have a pipeline which must comply with ASME B31.3, and I would like to install a short section (~2' - 4' long) of a special component which does not lend itself well to ASME B31.3 analysis, but can be analyzed per ASME Section VIII Section 1 and is not so complicated that it requires Section VIII Division 2. Of course, all B31.3 loadings and other requirements on the Section VIII component will be considered in the design such that it is purpose built to replace this section of piping.
Can this be done without any other special consideration?
