Hi all,
I need some clarification on ASME Section IX in regards to qualified thickness of a groove weld using the laser beam welding process. I have read a number of posts, but did not find many posts specifically related to LBW. A search for QW-403.3 did not bring up any relevant information. I am trying to determine at what thicknesses I need to qualify in order to achieve the desired parameters for a new WPS. I am trying to qualify 0.025 in. to 0.050 in. thick base metal on one WPS. The weld is joining sheet to a plate with a machined step that acts as an integral backing plate (the machined step depth is matched to the thickness of the sheet).
First, I believe I have correctly worked through the code to determine requirements for WPS development. QW-202.1 sends me to QW-451.1 to determine relevant testing. The notes on QW-451.1 send me to QW-403.2, .3, .6, .9, .10; QW-404.32; and QW-407.4 for additional limits on thickness qualified. QW-264 (LBW Essential Variables) tells me that QW-403.3 is the only relevant note from the notes of QW-451.1. (I think I have it right up to this point).
QW-403.3 states:
Where the measurement of penetration can be made by visual or mechanical means, requalification is required where the base metal thickness differs by 20% from that of the test coupon thickness when the test coupon thickness is 1 in. and under, and 10% when test coupon thickness is over 1 in. Where the measurement of penetration cannot be made, requalification is required where the base metal thickness differs by 10% from that of the test coupon when the test coupon thickness is 1 in. and under, and 5% when the test coupon thickness is over 1 in.
The test coupon is <1 in., so this all comes down to whether or not "measurement of penetration can be made by visual or mechanical means." If yes, then I would interpret this to mean that the WPS is valid for +/-20% of the test coupon thicknesses. Otherwise, we are limited to +/-10% of the test coupon thickness. This would mean that in order to achieve our WPS thickness range goal, we need additional PQRs.
We are using destructive analysis (macro etch) on a sample of parts during production to determine penetration. We cannot do a direct visual measurement of penetration due to an integral backing plate. I don't think our DE meets the definition of "mechanical means" but, for me, that is the hang up. Where are the "mechanical means" defined? I'm having a tough time understanding whether I fall in the +/-20% or +/-10% range.
If anyone has any feedback on this one, I would greatly appreciate it. Hopefully I'm not hopelessly lost on this one... I'm shooting for partially lost. Partially lost, I can manage.![[wink] [wink] [wink]](/data/assets/smilies/wink.gif)
Thanks!
-Ryan
QW-403.3 states:
Thanks!
-Ryan
