Typical Bellows Expansion Joints are shown in Figure 26-1-1.
The figure depicts two unreinforced bellow methods.
Method-1 : Internal Bellows Attachment
Method-2 : External Bellows Attachment
As I understood
- In case of internally type : The end pipe attached to both ends of the bellows reinforces the end of the bellows. Therefore, it is more robust against internal pressure.
- In case of externally type : It is easy to repair because the welded part is exposed to the outside.
Could you possibly provide me with any technical suggestions? What is appropriate for each type?
As I understood
