nathanael87
Petroleum
I have a WPS with two SMAW processes for example E6010 root and E7018-1 fill and cap.
According to ASME Sec. IX QW-200.4 I can use just one of those filler metals individually in a joint.
eg. I can use this WPS to use E7018-1 for an entire weld - root, fill and cap. We use this for welds on vessels.
What sort of calculations are required to determine if welding with that filler metal alone will be suitable for a particular joint?
I understand that E7018-1 is only going to improve the weld whilst losing a bit on penetration characteristics, and freezing at a slower rate (why it isn't used on piping as there would be a risk of more icicles).
Now, say in the case of a different procedure with GTAW/SMAW for P5B 5Cr eg. ER-80S-B6 root, E-8018-B6, apart from GTAW having excellent penetration and being a cleaner weld. Is there any other benefit to it? Depending on the process running through the pipe, is having the GTAW root going to be that much better?
The reason I ask this is because we have a tie-in weld on a long line and using shielding gas will be difficult and costly.
