Are all of the components mounted on the skid of a package centrifugal air compressor excluded from the ASME code? Typically centrifugal air compressor manufacturers install a tube and shell oil cooler on the air compressor skids of packaged compressor units. Most manufacturers do not relief valve protect either the oil side or the water side of these code stamped heat exchangers. All of the manufacturers that I have contacted content that so long as the compressor unit is properly installed, maintained and operated there should be no safety / code compliance issues. I.e., the compressor cooling water system pump dead head is less than maximum allowable compressor cooling water supply pressure or the compressor cooling water system is relief valve protected at a pressure that is less than allowable compressor cooling water supply pressure. Code requires that all code vessels be relief valve protected. I assume that this means that both the shell and tube side must be relief valve protected, (do both the shell and tube side have to be relief valve protected?). If this is true than unless the entire compressor skid is code excluded most package centrifugal air compressor systems are in violation of code requirements.
Do all code stamped vessels have to be relief valve protected? For example, does a code stamped heat exchanger that is less than 6" in diameter have to be relief valve protected?
Are these issues jurisdictional issues or are they cut and dry from cost to cost?
