Hello Community,
My question is about the ASME Code edition specified on the Mill Test Report. I see some reports specify the edition like ASME SA240/15 meaning the material is certified to Code edition 2015.
Now that 2019 code edition going into effect, which edition years do we need to accept?
[ol 1]
[li]As long as the material is certified to ASME Code (irrespective of the edition) it is acceptable.[/li]
[li]You need to verify the Chemical & Mechanical Properties of the raw material as shown on the MTR against latest ASME Code requirements to accept[/li]
[li]Compare ASTM standard edition range the 2015 ASME Code is accepting with 2019 Code edition, if both ASME editions accept the same ranges of ASTM standards, accept the material. In case the 2015 ASME code accepts wider range of ASTM standards than 2019 ASME Code edition, then reject.[/li]
[/ol]
I know it is confusing but this is the situation I'm going through right now.
Let me know what is your opinion?
Thanks,
[ol 1]
[/ol]
Thanks,
