Zoltan Racz
Dear all,
pls anybody tell me either these sentences are still valid or has eliminated from the code? If eliminated, when was?
'ASME BPVC.VIII.1-2015, UG-127, section (3-c-1):
the pressure relief valve will not fail to open at its proper pressure setting regardless of any back pressure that can accumulate between the pressure relief valve disk and the rupture disk. The space between the pressure relief valve disk and the rupture disk shall be vented or drained to prevent accumulation of pressure, or suitable means shall be provided to ensure that an accumulation of pressure does not affect the proper operation of the pressure relief valve.'
I have only the 2015 edition copy not the latest ones.
Appreciated - Zoltan
