It depends on what you intend to do with the ASME Code book sections. If you are using the code book sections to fabricate pressure retaining items under contract documents you will need to maintain the latest code book section editions. As of 2011, the next publication cycle is 2013 with no addenda. The ASME Code book sections will be on 2 year publication cycles. Code cases and errata are not affected.
