Greetings:
I am working with ASME Section VIII Div 1 2007 with 09 addenda. I have been asked to design a flat entryway cover for a round dust collector. The design positive pressure will be 40 psi. The cover will be a rectangular plate. I am calculating the minimum thickness in accordance to section UG-34 and Mandatory Appendix 2. This cover will be bolted on with an elastomeric seal. The issue I am having is with determining the variable W for the total bolt load. UG-34(3) accounts for non circular covers and heads, however the definition for W refers to 2-5(e) for the actual calculation of W. In MA 2 both the equations for Wm1 and Wm2 appear to be circular functions. My question is: Is there a section of the code that addresses flat, bolted covers. Or would it be acceptable to substitute rectangular parameters for the area and circumference that are noted in equations 2-5(1) and 2-5(2)?
Thanks.
"I drank what?!" Socrates?
Thanks.
