You are attempting to read the "gauge" beyond its accuracy. 1000 and 1020 psig are the same if the accuracy is +/- 1%. Back in the old days you would have mirrored scale "test gauges" with accuracies better than +/- 1%, at least in theory...As to a digital "gauge", it of course gives you "digital display bias", tricking your brain into thinking that all the figures displayed are significant when they absolutely may not be!
B31.3 has no requirements for the accuracy of test gauges. Your AI, if you have one, may point you to some and expect you to follow them. Here we have a procedure for checking shop gauges against a master transmitter which is sent out for calibration yearly. That satisfies our AI. The gauges we use are probably closer to +/- 2% within the measured range.
