ASME B31.1 & Section I material identification
qualitypro
91
Is there a requirement for Pipe spec markings and heat numbers to be transferred before cutting a pipe into pieces to ensure identification and traceability of every piece in the above ASME Codes for Code work? ASME Section I PG-77 only refers to plate identification. If there is please give the applicable section in these Codes.
Material traceability must be addressed in the Quality Control manual for an ASME stamp holder.
