Dec 1, 2020 #1 oguzzz Mechanical Joined Mar 1, 2020 Messages 15 Location TR What is the tolerance for inside and outside diameter of machining spiral wound gasket surface due to ASME B16.5 (For 6” nozzle). I saw exact measurements without tolerance regarding standard. Thanks.
Dec 1, 2020 #2 SnTMan Mechanical Joined Jan 22, 2005 Messages 6,859 Location US oguzzz, you are talking about the raised face, correct? It is addressed para 7.3 Facings (per 03 Ed). Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Dec 2, 2020 Thread starter #3 oguzzz Mechanical Joined Mar 1, 2020 Messages 15 Location TR Correct, I mean raised face. Thanks for quick reply. Regards. Upvote 0 Downvote
