Hello
I am an electrical engineer however have to design a cantilever suspension system even though I do not know much about the spring design.
Please look at the attached sketch. I use a flat spring (beam) to suspend an inertial mass to sensoring the ground motion. The beam is intially made of berrylim copper (c17200) solution annealed (TB00). Then the beam is pre-bent to a deflection of D at the end of beam (or a radius of R). Then it is heat treated hardened and acquire the elasticity.
The beam is fixed on the ground at one end. The other end is loaded with an inertial mass. When the beam is loaded, it is desirably the beam is flat.
Evidentally, the larger the pre-bend deflection D (i.e. the smaller the pre-band radius of curveture) of the beam, the more inertial mass M the beam can support when it is loaded to flat position.
My QUESTION is: what is the maximum deflection D (the minimum radius R) that I can pre-bend the beam (giving the beam dimensions)before the heat treatment, such that after hardening, the spring will work properly around flat position and would not fail due to the excessive stress?
Thank you a lot in advance
Tao
Tao
