At first I would like to add some comments to the Visitors post:
1. That's true, but that's a basic requirement and not a form of protection
2.Its true that the IGBT-chip itself doesn't contain an internal antiparallel diode, but for inverter applications a broad range of IGBT-power module are available where at least one IGBT and an approbiate antiparallel diode are integrated in one package. There are also small discrete devices availabel where an IGBT and an diode are integrated in one package e.g. TO220.
3. Breakdown volatge is an issue, but the most important thing is a low inductance design of the DC-link. Otherwise you will blow 3300 V devices with 100 V DC-link voltage.
The intrinsic diode in a Power Mosfet is usually not suitable for inverter applications (For rated breakdown voltages above 200 V) because of its poor reverse recovery characteristic. Only special devices containing an improved diode are suitable (e.g. FREDFETs from the SIPMOS-family)
Usually MOSFETs and especially IGBTSs can be protected against short circuit by a driver sensing drain resp. collector-voltage and turning a of the device within 10us.
In some modules IGBTs, diodes, driver, short cicruit protection, current sensor and tempeature sensor are already integrated.
(Visit
and look for Skiip-Modules).
If you want to work on space vector control you should avoid to reinvet the wheel and try to buy a suitable subsystems for the inverter. About ten years ago I even used an industrial manufactured inverter where I removed the controller-board for doing research an control methods.
