Referencing ASCE 7-10 (same in 05 but different section):
In Figure 30.4-2A (components and cladding h<=60ft) the GCp coefficient for zone 1,2,3 is in the range of 0.2 to 0.3 however per note 5 if the parapet height is greater than 3ft the GCp from Figure 30.4-1 (C&C walls) for zones 4,5 should be used which ranges from 0.7-1.0. Should positive pressure on the parapet really be increased this much?
To add to this confusion the 'user note' in figure 30.9-1 says to see Note 5 (referenced above) for "reductions in component and cladding roof pressures when parapets 3ft or higher are present".
Maybe i'm missing something...
Thanks in advance
EIT
Thanks in advance
EIT
