rowingengineer
How does the reinforcement Ratio affect Punching shear? I do not hold all/any the answers but the following is some references and a little of what I understand:
Concentrating the reinforcement over the columns as per AS3600 CL 9.1.2 will increase the stiffness of the slab. This will improve the column to slab connection, as moments are generally concentrated around the columns until redistribution occurs. This re-disputation is caused by cracking of the concrete; this cracking can affect the shear capacity. Hence the reinforcement reduces the crack widths such that the shear interlock between the aggregate is maintained.
References:
Elstner and Hognestad (1956), Regan (1974) and Zaghlool and de Paiva (1973) showed that increasing reinforcement ratio increases the punching shear strength Alexander and Simmonds (1992), from the test of eight-isolated interior Column-flat plate connections, found that decreasing the bar spacing at a certain steel ratio increase the punching capacity.
My Personal favourite book: Warner, Rangan et al. Chapter 19.5.
When in doubt, just take the next small step.
References:
