The suppliers usually have a data sheet that gives you the maximum overturning and slewing loads. I think they are actually based on a shorter design life on the assumption that the crane is only there for the construction period (I'd have to go searching to find one in my records to confirm). But even if it didn't I think you'd factor it down to something reasonable like less than 6 months or 5 years. It is intended to be the design installation life in accordance with AS1418 series of standards.
In terms of the foundation for a tower crane, it is considered temporary in that location if you like. The crane itself would of course need to be designed for the full design life that it will be in service.
The information they give you is very cryptic, often you are not even entirely sure what loads are or are not included, and sometimes a different configuration in terms of jib length or height. They are also envelopes so you cannot even back calculate out just the wind or seismic loads. Basically they make it really hard to determine what basis the loads were determined and they are not presented in terms of any of the tower crane load-cases from AS1418 for foundation design (refer to AS1418.4 table 2.4.3 for support structures). So you need to use a lot of judgement.
Half the time because the cranes have been on the market for a decade or two, a particular model might only have wind loads for older versions of standards (like NZS4203, the NZ loading standard before we adopted AS/NZS1170 joint standard).
So often we used to just take a huge load factor like 1.5 on the basis that the largest load factor in AS1418.4 is 1.6 for actions that contribute to the overturning and apply it just to be sure we weren't going to be the subject of the next YouTube crane collapse montage video... it was a fairly crude approach, but if something is likely to see it's design loading it will be a crane. Given the difficulty of sourcing information in the first place on loads and the frequency in which cranes fall over I'm surprised the suppliers and manufacturers don't have more complete information available to make a better assessment. I guess they sell more cranes if they fall down?!
They have in the past offered to provide more information or a specific assessment by going back to the original manufacturer and for ~1500 Euros provide some updated information. Never really took them up on that though.
The last few I did a few years ago and the crane is still up, as its part of a project that has seen it's fair share of troubles in the construction. 1.5 year total build time turned into 5 years now and still going (read 3/4 finished now)! So like you say taking a smaller design life has it's downsides.
