AS 1210
DiegoMartinez
Petroleum
AU
People,
I want to know what is the minimum thickness of a 10" gas scrubber fabricated from A240-316/316L SS based on AS 1210.
Rgds Brighton
Simple answer, get a copy of the Code.
In any case you didn't give enough information for anyone holding a copy to give you a solution.
Let me rephrase it: what is the minimum required thickness formula for a pressure vessel subjected to internal pressure?
Rgds D.M
People,
I want to work out the shell thickness of a vessel as per AS 1210 but I am unable to find a formula for minimum required thickness. Could anyone tell me what is the formula to work this out? Secondly, the process data is as follows:
Design pressure: 150 Barg
Material: Plate A240 316/316L SS
OD: 273 mm
Temperature: Ambient
Media: CO2
Rgds Diego
