Arrays of features or components
vitulin
Automotive
EU
I would like to ask, if its possible to create more enhanced array of features or components. For example creating circular array with two changing coordinates with each instance ( angle and Z coordinate ) or instances on a curve? All of these parametric and driven by expressions...
I would also like to ask, why I am not able to create array of bodies itself, but if I create a group containing for example just a single body, it works?
Can you use an array of group to create referenced component array?
Is it possible to create an array of datums?Planes,axis etc.
Vit
With NX 5, you can create instance sets of any geometric object, including solid/sheet bodies, curves, points, faces, etc. using the 'Instance Geometry' function.
However, this cannot be used to Instance Features or Components.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
