BioMechanic001
We need to repair face of Thrust Disc with details below.
Thrust Dis Material : SS 304
OD of Disc: 275 mm
Thickness of flange : 28.50 mm
Coating Thickness : 1 mm
Service provider suggested to use SS420 wire. Now we need to verify the compatibility of coating material with base material SS304 based on the standard ASME Section II.
OD of Disc: 275 mm
- Is this SS420 Wire is compatible with the base material SS304?
- Based on the standard ASME Section II is it acceptable to use the SS420 wire for the coating on SS304 Material?
