We have a 100' long heated(in winter) scale for weighing pulp trucks. At each end is a 10' long x12" thick approach slab which is deteriorating immediately adjacent the scale where the tires run over. The potholes are 30"x30" and 4" deep and appeared slowly over the past 5 years since installation. Is there something other than freeze/thaw or deicing salt damage going on here. Could it be the transition from the scale to a different surface. Has anyone seen a similar type situation before? One more thing, one end of each apron slab is free and one end is tied with rebar into the end wall supporting the scale. We've checked the axle loads vs thickness and we have a F.S. over 4 so I don't think stress at the support is an issue.
