Applying Shell pressure in Ansys
speed320
Hi all,
I have looked for any existing help files on the subject but no luck.
This may seem straightforward, but I am trying to apply a normal pressure on a plate. When I plot the symbols, it shows pressures applied on the edges of the plate (in plane). I've meshed the area with shell63 elements and changes in Keyopts do not give me the required direction.
Once again this is probably straightforward, but I cant figure it out. Thanks in advance.
this is the way Ansys marks the pressures: on the edges of elements. In the solution phase, Ansys will compute the normals to the elements faces and the area of the element faces. So from what you are describing, there is nothing abnormal with your model.
Alex
As Alex said, it's just the mark of pressure.But you really want to see the pressure applied on element, you can change the symbol of pressure, you can use '/PSF' command to chang the symbol to arrows,which makes it easy to check if the direction of pressure is right. Because when shell element type is used, there might be different element coordinates on different areas.
Thx guys, that worked....I guess I was worried about nothing. My results do look OK.
Cheers
Speed320
