luungoclinh
Hi there,
1) Could some one tell me how I can define sequence of load applying to the building in Etabs 3D? I ask that question because I am familiar with another software like Perform 3D that I can define to apply gravity load firstly then seismic load. In Etabs, will it follow that sequence automatically or we need to define?
2) How to define gravity load? Do we do it by using static load case (dead) or we could do it by using whatever load cases we want then add them to the load defined as gravity load. That question is because I just model the building with only shear walls. Therefore I just want to model the gravity load from the tributary areas of the shear walls. Normally, with Perform 3D, I do it by using directly concentrate load assigning on the wall. Can I do the same procedure in Etabs 3D?. How can I let Etabs understand these concentrate loads as gravity load and applying before seismic load?
Thanks in advance
Lisu
Thanks in advance
Lisu
