SEISMIC USER DEFINED LOAD
Angel Vila
I have a rigid diaphragm structure and modeled seismic user-defined loads as shown in Image 1. Once I run the analysis and display the joint loads, it shows a vertical component on each floor (Image 2). Does anyone know what these are? and how to turn these off.
 https://files.engineering.com/getfile.aspx?folder=0a8600c4-56fb-4f36-a144-2c2e2386ed7b&file=Image_1_&_2.pdf
Sorry, please see attached. Thanks!
Did you manually apply that load to the joint under seismic Y? The double arrow head in your image means that is a twisting moment (Mz), not a vertical load.
