Using FEMAP 9.3, I know to apply a acceleration constant you input your valuel within Model-Load-Body and you add your density to the material card. My first question is what do you put for a value to similate gravity. Looking at the help section, it says that the inputted value isn't G's. However comparing hand analysis versus the model of a cantilevered plate element using a value of -1 in the z-direction(normal to my plate), this is the only way to get similar numbers. However checking the freebody display, the loads are half of what they should be.
I also tried a value of -2. Checking the freebody display, the loads correlate, but the displacement is off. I tried three different assumptions: a cantilevered beam with a distributed load, a mid span point load, and an end point load. The end point load had only 5% error but the other two had much larger errors. I was assuming a gravity load would act like 1 or 2 not 3. This probably relates to my first question.
