H
headrush
Guest
Imagine a can. Acylinder with twoend caps. A can like a can of beans you buy at the grocery store. I want to compress this can axially. The can is made of a very soft material.
It's in a cylindrical coordinate system.
I cut it in half along the z axis. So I have half a can - a cylinder withone end cap.
I want to fix all DOF on the end cap and apply a z direction force to the symmetry surface. We don't typically apply forces to symmetry surfaces (at least I haven't used this technique before).
The correct symmetry constraints for this symmetry surface (if I were to apply the force to the end cap) are to fix translation in z and fixrot-R and rot-theta. I should simply be able to remove the constraint on trans-z and apply the force to the symmetry surface. The problem runs, but I still get rotation about theta even though the rot-theta DOF is fixed. So the edge I cut in the middle of the can bends outwards.
Ibelieve this result is caused by a bug in Mechanica, or maybe what I would term a severe limitation. Although I have now been successful at soving the problem by applying the force to the end cap, I am still surprised as to why applying the force to the symmetry surface doesn't work.
Any ideas?Does it sound like a bug to you? I am running WF3.0 M080. I couldn't find any known problemson the PTC website.
Edited by: headrush
Edited by: headrush
