Focht has hit the pin on the head!!!
The test is run when the pin is driven into the soil. The nuclear gauge gives numbers to record.
Here's what the inspector should be paying attention to:
1. Does the pin drive with the same resistance for the entire length(depth) of insertion?
Lower resistance with depth means the compactive effort is insufficient and/or the lift thickness is excessive. Increasing resistance with depth means sufficient or excessive compactive effort, or a change in (denser)material.
2. Does the pin drive with a similar resistance as the same material elsewhere on site?
Uniformity of resistance means consistant material and effort.
Is pin resistance similar for similar materials on different sites?
Again, uniformity of materials and effort for those of us blessed with processed materials used on a majority of sites in the area.
Density measurements include about 2 to 3 inches below the bottom of the probe, depending on the density. Looser or denser soil imediately below the probe can affect the reading. Hence a backscatter is inappropriate for lifts exceeding 2 to 4 inches. Try to have the test depth 2 inches less than the lift thickness.
Big vibratory compactors get maximum densification 2 to 3 feet below the surface, therefore it's not a bad idea to dig for tests. Also, have the vibration turned off for final passes on the top lift (static rolling) otherwise the top portion of the lift is loosened by the vibration (more prevalent on finer cohesionless material). Well graded material sticks together somewhat better.
Who will do a research project correlating vibration frequency with grain size or finess modulus?
Focht3
I'e found that density readings are not appreciably affected by test duration. Have you found otherwise? I believe it is the moisture reading that is more time dependent. The solution is to correct as compared to oven-dry as discussed in my previous post. The majority of soils tested in my area are lime or silica sands or soft limestone prepared aggregates. I have less recent experience with clays which appear to be more prevalent in your area. Maybe we need to start a new topic?
![[cheers] [cheers] [cheers]](/data/assets/smilies/cheers.gif)
