Mechanimal
I was wondering if anyone knew if ASME Section VIII Division 1 Appendix 41 can be used for external pressure calculations?
The definition of P in Appendix 41 is design pressure and does not refer to internal or external as it does in UG-34 (UG-34 is only for internal pressure, see interpretation VIII-1-89-206).
From my understanding Appendix 41 is really just UHX 12 U-tube tubesheet design procedure with Pt=0, and configuration d. The interesting thing is that UHX 12.3 defines Ps as the shell side design pressure, for vacuum service use a negative value for Ps.
Would that be the case with Appendix 41?
The confusion for me is in the external pressure restriction in UG-34 for blind flanges. I don't understand from the Roark equation derivation how external pressure would result in a different thickness than internal pressure. If you absolute the moments similarly to UHX the results are same.
