Can anyone point me in the direction of some calculations to help me determine if I should recommend stiffeners for a door cut into an API tank? Recently a 6ft x 6ft door was cut into the side of an ~80ft diameter tank to do some work, and I would think stiffeners would be needed for such a large cut, but the tank vendor said that it was a relatively small cut on this size tank and stiffeners are not needed.
I just need some way that I can quickly determine if stiffeners would be needed or not for future needs.
The recent tank is a clarifier and has a walkway from the shell to the middle where the rake motor is. Shell thickness is 1/4", height is 22ft. For this particular one, I recommended stiffeners and was told that it was no big deal to tack them on temporarily for the work, so it was fine. I'd like to be more certain next time.
