API Question
SilasH
New member
I'm attempting to make a macro (not something that I'm very good at) that given a width and height of a plate, will create a centered array of holes at 2" on center. I can get it to create the right number of holes, but I can't get them to center, so that I often end up .75" from one side and 1.25" from the other side.
The code Part.Parameter("DimA@Sketch1").SystemValue = (Insert formula here) doesn't seem to be taking. If I set it equal to a simple numerical value, however, it changes. The actual formula I used is
Width / 2 + 1 / 39.3700787 - ((39.3700787 * Width + 1.25) \ 2)
where Width is defined in inches, and I know that it is defined, since the formula to determine the number of holes uses it (that's the second half of the above equation). I'm at a bit of a loss here.
SilasH,
SystemValue is in meters. Is this what the 39.3700787 is doing. I normally use 25.4 to do all my conversions.
Regg
Yes, that's the conversion into inches. My problem is that for some reason, those lines aren't running when I have the formula in there, but they will if I have a simple numeric value. I used the Width value a couple lines previous to it, and it worked just fine. Here's the complete code, in all of its hack and slash glory:
Dim WidthHoles As Double
Dim HeightHoles As Double
Dim XOffset As Double
Dim YOffset As Double
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
GPForm.Show
Height = GPForm.Height / 39.3700787
Width = GPForm.Width / 39.3700787
Mil = GPForm.Mil / 39.3700787
XOffset = Width / 2 + 1 / 39.3700787 - ((39.3700787 * Width + 1.25) \ 2)
YOffset = Height / 2 + 1 / 39.3700787 - ((39.3700787 * Height + 1.25) \ 2)
Set GPForm = Nothing
Part.AddConfiguration "GP" & Height * 39.3700787 & "-" & Mil * 39370.0787 & "-" & Width * 39.3700787, "", "", 0, 0, 0, 1, 256
Part.Parameter("width@Sketch1").SystemValue = Width
Part.Parameter("height@Sketch1").SystemValue = Height
Part.Parameter("Thickness@Sheet-Metal1").SystemValue = Mil
Part.Parameter("D1@LPattern1").SystemValue = (39.3700787 * Width + 1.25) \ 2
Part.Parameter("D2@LPattern1").SystemValue = (39.3700787 * Height + 1.25) \ 2
Part.ForceRebuild
Part.Parameter("y-offset@Sketch3").SystemValue = 0.0254
Part.Parameter("x-offset@Sketch3").SystemValue = 0.0254
Part.Parameter("x-offset@Sketch3").SystemValue = Width / 2 + 1 / 39.3700787 - ((39.3700787 * Width + 1.25) \ 2)
Part.Parameter("y-offset@Sketch3").SystemValue = Height / 2 + 1 / 39.3700787 - ((39.3700787 * Height + 1.25) \ 2)
'Part.Parameter("x-offset@Sketch3").SystemValue = XOffset
'Part.Parameter("y-offset@Sketch3").SystemValue = YOffset
Part.ForceRebuild
End Sub
You can see I've tried a couple different ways to get the holes to center, by direct formula, and by variable. Still, no luck.
Here's one problem - your final "divide by 2" operation is attempting to use a backslash (\) rather than a frontslash (/).
The values still have to be in meters when setting the system value
From what I read in the API notes, the \ returns an integer value, which is what I wanted, i.e. 100 \ 3 = 33. And that formula works correctly to give me the number of holes on the sheet.
SilasH,
From your original post:
The first half of that formula (Width / 2 + 1 / 39.3700787) is converting an inch value to meters, so if the Width was 6 inches entered into the Dialog Box, that value equates to 0.1524 here...OK that looks all right, not the way I would do it, but it should work.
The second half of that formula ((39.3700787 * Width + 1.25) \ 2) is dealing with whole numbers like 1, 2,3, etc...Not in sync with the first half of the formula.
Resulting in a decimal minus a whole number, which is always going to be negative...and cause problems with the linear pattern.
So the error is in your formula, no matter where you put it.
I did fix the code, but considering that the "Part.AddConfiguration" line is wrong. And that you use "/39.3700787" instead of "*0.0254"...I really don't want to do all your homework for you.
Ken
To build on Ken's response, you need to figure out whether the result of your
formula is giving the value you expect. Try
MsgBox Width / 2 + 1 / 39.3700787 - ((39.3700787 * Width + 1.25) \ 2)
Ahhhh, I gotcha. Doh. Thanks!
