ThomasH
- Feb 6, 2003
- 1,192
Hi all
I have a question that hopefully somebody can answer.
I you have done any API programming in Femap you may know that there are methods to create cross sections for line elements. As far as I know these methods are based on the standard parametric cross sections, like a tube with radius and thickness.
But there is a general section based on a surface. Basically I can draw a cross section and Femap will calculate all the section data. I can also do that but what I would really like is to be able to program the cross section so the graphics in the model would look correct.
Is there a way to send the cross section directly into the beam properties shape dialog as a coordinate matrix or anything similar? I can't find any info on this in the manuals.
Best regards
Thomas
Best regards
Thomas
