pneveu
- Mar 14, 2008
- 9
What are the common tests required after repairs are made to the shell of an API 650 tank? It is 40' tall and holds 10,000 barrels? The bottom course is 1/4" thick. We are planning on replacing an area 10" high by 60" long right above the tank bottom. My take on reading the code is radiography on the butt joints and dye penetrant for the shell to bottom joint. Filling it with water will be an expensive and difficult problem. Will an air pressure test or other testing still be required?
