I have a few questions regarding API 650 Section P. Any assitance is appreciated.
1) Section P.1 indicates that the appendix shall be used for tanks greater than 36m diameter and tanks less than 36m diameter only when specified by the purchaser. Are there any issues with using the appendix for tanks < 36m diameter? Are there alternate methods better suited for tanks < 36m?
2) Can section P.2 be used to calculate radial growth, and stiffness coefficients for nozzles above the lower half of the bottom shell course? If not, how are these factors determined in order to calculate the nozzle loads?
3) If using P.3 to calculate local stress due to nozzle loads, can the stiffness coefficients in P.2 be used to calculate the nozzle loads?
