vinalso85
- Apr 30, 2010
- 4
Hi!
To determine the backpressure in the discharging piping of a safety valve, API 521 recommends the use of isothermal relations. The method consist in calculate the pressure at the piping inlet backward from the pipe outlet. The pressure in the outlet will be the maximum of the atmospheric pressure and the critical pressure.
The critical pressure and Mach numbers for a isothermal flow depend on the flow temperature T (which is constant along the flow by definition). API does not specify (or at list I could not find anywhere) how to estimate the flow temperature.
What should be the flow temperature?
a) The surrounding temperature, since we are assuming isothermal flow due to the heat transfer with the environment.
b) Relieving temperature / design temperature / system temperature (whatever we are using to the determine the valve flow rate). This is clearly not the actual behaviour since the isothermal flow starts somewhere downstream the valve oulet, but maybe a conservative approach.
c) Something else
Thanks!!
c) Something else
Thanks!!
