Justice100
Chemical
Hi all,
API 14c states that a high pressure trip on the pump (others) discharge is not required if the “Maximum discharge pressure does not exceed 70pc of the maximum allowable working pressure of the discharge piping”.
It also states a psv on the discharge is not required if “Maximum discharge pressure does not exceed the maximum allowable working pressure of the discharge piping”.
I am used to designing pump systems to the latter psv statement but I can’t understand the 70pc part regards the high pressure trip? Why is a larger margin required?
