Anyone have a macro to print all drawings in open files?
SwagOne
8
I create my assemblies and drawings per the master model format. The assemblies I create can have 7-10 drawings total all in separate files. If I open all the drawings in drafting, does anyone has a macro, grip, or vb that will print all the drawings in the open files with a few (one) clicks?
I have tried recording macros, but I haven't figured out how to make it generic enough to work on other files.
Try the code below:
Code:
[COLOR=blue]Option Strict Off[/color]
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] System.Windows.Forms
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Module[/color] Module1
    [COLOR=blue]Dim[/color] theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
    [COLOR=blue]Dim[/color] defaultPrinterName [COLOR=blue]As String =[/color] ""
    [COLOR=blue]Sub[/color] Main()
        [COLOR=blue]Dim[/color] workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
        [COLOR=blue]Dim[/color] lw [COLOR=blue]As[/color] ListingWindow [COLOR=blue]=[/color] theSession.ListingWindow
 [COLOR=green]'lw.Open()[/color]
        [COLOR=blue]Dim[/color] printerSettings [COLOR=blue]As New[/color] System.Drawing.Printing.PrinterSettings
        [COLOR=blue]Try[/color]
            defaultPrinterName [COLOR=blue]=[/color] printerSettings.PrinterName
        [COLOR=blue]Catch[/color] ex [COLOR=blue]As[/color] System.Exception
            defaultPrinterName [COLOR=blue]=[/color] ""
        [COLOR=blue]Finally[/color]
            printerSettings [COLOR=blue]= Nothing[/color]
        End [COLOR=blue]Try[/color]
        [COLOR=blue]If[/color] String.IsNullOrEmpty(defaultPrinterName) [COLOR=blue]Then[/color]
            MessageBox.Show("No [COLOR=blue]default[/color] printer found.", "Printer error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            [COLOR=blue]Return[/color]
        End [COLOR=blue]If[/color]
        [COLOR=blue]For Each[/color] tempPart [COLOR=blue]As[/color] Part [COLOR=blue]In[/color] theSession.Parts
            [COLOR=blue]If[/color] tempPart.IsFullyLoaded [COLOR=blue]Then[/color]
 [COLOR=green]'lw.WriteLine("part: " & tempPart.FullPath)[/color]
                ChangeDisplayPart(tempPart)
                [COLOR=blue]For Each[/color] tempSheet [COLOR=blue]As[/color] Drawings.DrawingSheet [COLOR=blue]In[/color] tempPart.DrawingSheets
 [COLOR=green]'lw.WriteLine("  sheet: " & tempSheet.Name)[/color]
                    tempPart.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, tempSheet)
                    PrintSheet(tempPart, tempSheet)
                [COLOR=blue]Next[/color]
 [COLOR=green]'lw.WriteLine("")[/color]
            ChangeDisplayPart(workPart)
 [COLOR=green]'lw.Close()[/color]
    End [COLOR=blue]Sub[/color]
    [COLOR=blue]Sub[/color] PrintSheet(ByVal thePart [COLOR=blue]As[/color] Part, [COLOR=blue]ByVal[/color] theSheet [COLOR=blue]As[/color] Drawings.DrawingSheet)
        [COLOR=blue]Dim[/color] printBuilder1 [COLOR=blue]As[/color] PrintBuilder
        printBuilder1 [COLOR=blue]=[/color] thePart.PlotManager.CreatePrintBuilder()
        printBuilder1.PrinterText [COLOR=blue]=[/color] defaultPrinterName
 [COLOR=green]'printer settings, change as desired[/color]
        printBuilder1.Copies [COLOR=blue]=[/color] 1
        printBuilder1.ThinWidth [COLOR=blue]=[/color] 1.0
        printBuilder1.NormalWidth [COLOR=blue]=[/color] 2.0
        printBuilder1.ThickWidth [COLOR=blue]=[/color] 3.0
        printBuilder1.Output [COLOR=blue]=[/color] PrintBuilder.OutputOption.WireframeBlackWhite
        printBuilder1.RasterImages [COLOR=blue]= True[/color]
        printBuilder1.Orientation [COLOR=blue]=[/color] PrintBuilder.OrientationOption.Landscape
        printBuilder1.Paper [COLOR=blue]=[/color] PrintBuilder.PaperSize.Letter
        [COLOR=blue]Dim[/color] paper1 [COLOR=blue]As[/color] PrintBuilder.PaperSize
        paper1 [COLOR=blue]=[/color] printBuilder1.Paper
        [COLOR=blue]Dim[/color] sheets1(0) [COLOR=blue]As[/color] NXObject
        sheets1(0) [COLOR=blue]=[/color] theSheet
        printBuilder1.SourceBuilder.SetSheets(sheets1)
        [COLOR=blue]Dim[/color] nXObject1 [COLOR=blue]As[/color] NXObject
            nXObject1 [COLOR=blue]=[/color] printBuilder1.Commit()
        [COLOR=blue]Catch[/color] ex [COLOR=blue]As[/color] NXException
 [COLOR=green]'log error[/color]
            printBuilder1.Destroy()
    [COLOR=blue]Public Sub[/color] ChangeDisplayPart(ByVal myPart [COLOR=blue]As[/color] Part)
 [COLOR=green]'make the given component the display part[/color]
        [COLOR=blue]Dim[/color] markId1 [COLOR=blue]As[/color] Session.UndoMarkId
        markId1 [COLOR=blue]=[/color] theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Display Part")
            [COLOR=blue]Dim[/color] partLoadStatus1 [COLOR=blue]As[/color] PartLoadStatus
            [COLOR=blue]Dim[/color] status1 [COLOR=blue]As[/color] PartCollection.SdpsStatus
            status1 [COLOR=blue]=[/color] theSession.Parts.SetDisplay(myPart, False, False, partLoadStatus1)
            partLoadStatus1.Dispose()
            theSession.UndoToMark(markId1, "Display Part")
            theSession.DeleteUndoMark(markId1, "Display Part")
    [COLOR=blue]Public Function[/color] GetUnloadOption(ByVal dummy [COLOR=blue]As String[/color]) [COLOR=blue]As Integer[/color]
 [COLOR=green]'Unloads the image when the NX session terminates[/color]
        GetUnloadOption [COLOR=blue]=[/color] NXOpen.Session.LibraryUnloadOption.AtTermination
 [COLOR=green]'----Other unload options-------[/color]
 [COLOR=green]'Unloads the image immediately after execution within NX[/color]
 [COLOR=green]'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately[/color]
 [COLOR=green]'Unloads the image explicitly, via an unload dialog[/color]
 [COLOR=green]'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly[/color]
 [COLOR=green]'-------------------------------[/color]
    End [COLOR=blue]Function[/color]
End [COLOR=blue]Module[/color]
www.nxjournaling.com
Thank you, cowski! It works great for printers. I am going to try and modifiy it to do PDFs.
