This is a very basic example of such an issue where the defining spline has 2 redundant points or you could say split in 2 (i believe it originated from AutoCAD) but previous history is not available so there is no way to fix the spline other than re-creating the feature.
Is there a tool in Synchronous modeling that can do this job? I've tried some of the tools but i can't seem to find a way to make it work.
Basically a tool like "Delete Edge" that can work with a solid model
Kind regards
