CAS A23.3-19 clause 21.5.3.4 Conditions for reduced wall thickness
Limit A in Clause 21.5.3.2 and Limit B in Clause 21.5.3.3 shall not be required to apply to
a) any part of a wall that under factored vertical and lateral loads are not more than halfway from the neutral axis to the compression face of the wall section;
What does "not more than halfway from the neutral axis to the compression face of the wall section" mean? Would you draw a sketch to show the intent of the language?
